Results 1 to 10 of 16
Thread: November 2016, Release Candidate 1
    Default November 2016, Release Candidate 1
    Please download and install both the V7.5 and V8 software packages.
    IMPORTANT:
    During the beta test phase, the EFILive software and firmware version numbers have been updated multiple times as follows:
    • Version 7.5 software: V7.5.7 to V7.5.8 and again to V7.5.9.
    • Version 8 software: V8.2.2 to V8.2.3 and again to V8.2.4.
    • Firmware: V2.07.104 to V2.07.105 and again to V2.07.106
    Those version number changes reflect two major compatibility updates:
    1. The *.ctz and *.coz tune files' internal formats have been updated.
      Any tune file saved with one version cannot be opened using a previous version.
      A tune file saved with a previous version can be opened with a later version.
      For the purpose of determining tune file compatibility, the third digit of the software version number is used.
    2. The *.obj read/flash script files have been updated.
      If you create a *.bbx quick setup file for your customers' AutoCal devices using this software and firmware version, then you must ensure that the users' AutoCal devices are also using this software and firmware version.
    Release Notes:
    Key Features:
    • 2017 Cummins support.
    • Controller Authorization to manage heightened security protocols for 2017 GM controllers.
    • The first release of 2017 GM vehicle support including updated E92 Corvette and E82 ECM for LGX 3.6L V6.
    • Changes to Remote Linking/Unlinking of AutoCal.
    • Updated documentation to support recently added features.
    Please note, with many new OS's released for 2017 models over several different ECM types, unsupported OS's may take some time to be completed and may not be currently supported in this release.
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.9 Build 315 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.4 Build 309 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.107 (Nov 21, 2016)To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue 1:
    Workaround:
    None.
    It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available and fully integrated with the V8 tuning tool software.
    Issue 2:
    When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
    Workaround:
    EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
    Thanks.
    Lifetime Member wesam's Avatar
    May 2010
    EFILive Tuner
    Jul 2003
    super thanks
    May 2015
    Could someone elaborate on:
    - Changes to Remote Linking/Unlinking of AutoCal.
    Feb 2006
    Quote Originally Posted by PSS View Post
    Is explained here:
    http://www.efilive.com/latest/autoca...and-unlinking/
    & Here:
    https://forum.efilive.com/showthread...hlight=linking
    Feb 2006
    I have a friend with an ecu/engine from a wrecked foton tunland with the 2.8td. Took a look at the ecu and it's a continental. Would you guys like to take a look\crack at it?
    Is that the Cummins ?
    Feb 2006
    It is indeed.
    http://www.fotonmotors.com.au/foton/...ab%20Styleside
    I thought it was an e98 controller at first, but it's a little bigger.
    Yeah, some weird one-off Cummins thing.
  1. November 2016: EFILive Beta Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: November 21st, 2016, 05:23 PM
  2. July 2016, Release Candidate 3
    Last Post: August 26th, 2016, 09:51 AM
  3. June 2016 Release Candidate 2
    Last Post: August 17th, 2016, 12:48 AM
  4. June 2016 Release Candidate 1
    Last Post: June 13th, 2016, 10:44 AM
  5. November 18th 2010 pre-release
    Last Post: December 2nd, 2010, 05:04 PM
