Results 1 to 10 of 14
Thread: Math for the VE multiplier
Hybrid View
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Question Math for the VE multiplier
    Howard got me set up w/ my head cam, and now I want to play more with COS5.
    How do I estimate what I need for the VE multiplier if I want say 11.8 for my AFR above 3000 RPM...
    Basically I start lean (so I want to add some fuel down low 3000's), and as it goes to 6000 RPM it goes rich to 10's and 11's for AFR (so I want to lean it out upper RPM).
    I want to make the VE multipliers to try and manage this w/ the nitrous toggle is enabled.
    Whats the math to do this? Guessing I use MAF Grams/Sec as a starting point, then refer to the appropiate VE cells? and do what next?
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Lifetime Member Doc's Avatar
    Oct 2005
    You have to have your commanded vs. actual AFR's very tight to begin with. Assuming you do, if you have an area that when on the motor alone you are commanding say 12.5 AFR, (1.17 EQ Ratio) and you want to be 11.8 AFR (1.239 EQ Ratio) then your difference would be .7 AFR (.069 EQR).
    Notice how the table units are in "FACTOR", this is how the pcm crunches the numbers, as you should also. AFR is logrithmic and the pcm cannot do the higher math to come up with the new enrichment number. You would need a multiplier of 1.069 in the rpm cell(s) that you want the enrichment to happen in.
    Remember, EFI Live provides the AFR units just for our motorhead brains as a crutch. It's best to start walking like an Egyptian or pcm in this commanded fueling business.
    www.efialchemy.com
    www.greatamericancarwar.com
    Jul 2006
    Assuming the case above, Its commanding 12.5 and N/A I get 12.5 +/- and I want 11.8 @ 3000 RPM instaed of the 12.5 when spraying...I enter 1.069 on the 3000 RPM entry?
    As it goes Lean to rich, I should end up say at .931 if I am 11.1 AFR @ 6000when spraying (to get 11.8 ) ?
    Maine USA
    Oct 2005
    Quote Originally Posted by Beer99C5
    Yep
    As it goes Lean to rich, -ummh???!!!???
    www.efialchemy.com
    Jul 2006
    Quote Originally Posted by Doc
    Yep
    Here is a screen (this is a 50 Dry @ 2800 and a 50 wet @ 4000), this shows the fuel pressure drop, when the wet kicks on @ 4000 RPM.
    With the drop you can see the AFR rise until the pump recovers.
    I want to counter the AFR Spike, so I intend to use the multiplier to try and get a steady 11.8 or so during the entire Nitrous run. Near the end of the run you can see its 10.00's, I want to raise that so I would be looking at .9XX or so for the multipler there?
    Maine USA
    Beer,
    I don't think the PCM can respond fast enough to get rid of one spike. Nor is it detrimental to the motor. You need to look at average trends for your changes. What size and combination are you going to stick with? 50/50?
    I would make a quick spreadsheet noting actual AFR vs requested AFR (on spray) and calculate of the percentage of difference. This then can be converted to EQ ratio and used in that table.
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Default Learning...
    Question: can it be calculated like this instead: 1.239/1.17 = 1.059...?
    (i.e. treated purely as an EQ multiplier without thinking of AFR difference)
  1. Somebody check my IFR math - won't start now!
    By Mr. P. in forum Gen III V8 Specific
    Last Post: September 9th, 2009, 05:44 PM
  2. WB Volts vs. AFR math needed!
    By Redline Motorsports in forum General
    Last Post: March 12th, 2009, 04:54 AM
  3. Math needed for gms/sec vs lbs/minute
    Last Post: October 23rd, 2006, 10:45 AM
  4. Math ?
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 9th, 2005, 02:00 AM
  5. Math Wizzards - BEN Factor IAT correction
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: July 29th, 2005, 02:56 PM
