Results 11 to 20 of 24
Thread: Need some help from the EFI Live Community. Paul, Ross, Joe?
    Oh, so you are using the 4T65E... then the ratios would be correct see post #6.
    Dec 2007
    Quote Originally Posted by finishline View Post
    The complete drive line is from the 07 Impalla SS, including the wiring harness, TCM and the ECM. Notice the vin numbers are all the same. I assume the gear ratio's are correct. The car does shift where it's supposed to. I tried some other things you can't see in the files I posted. Since they didn't fix the problem I put them back to stock. The file I posted is the one we are running on right now. I will try everything that has been suggested as soon as the weather clears.
    On another note, the car comes with a traction control button just like the corvettes I usually work on. I wonder which wire that signal comes in on the E67 ECM and if it's just a ground signal? Anybody know?
    Thanks everyone for the compliments. Actually this is only the third engine swap like this in the U.S. and it was my customers idea not mine. He did a ton of research and it was a very smooth swap except for this throttle blade issue. He does plan to drive the wheels off this thing after we get all the little bugs worked out.
    Thanks for the suggestions and please keep them coming.
    Ok so Fiero is front wheel drive and you are using the 4T65? Oops. Dyslexia getting worse .
    Normally GM runs the traction control into the BCM.
    Ian, you have a pm...
    Sep 2006
    Try maxing out the values in B2517 and see if that helps. It seems strange that you're getting this as you have already disabled pretty much ever other TCS setting. 0-60mph in 5.3 is not a bad effort though......
    I made a file with the table set to 8000. We'll run the file on the car as soon as the weather clears up.
    Thanks.
    Sep 2006
    Thanks to everyone that has made suggestions. I've made 5 different files with your names on them so I can give credit where it's due when we resolve this. Man I sure hope we don't have to bring the BCM into this to get it resolved.
    FYI for those that don't know, the Fiero is a rear engine rear wheel drive GM product. We just used the Impalla SS front wheel drive engine and tranny and moved it to the rear of the Fiero. Pretty slick swap.
    Thanks again guys!
    Post some pics...
    Sep 2006
    One from the top and one from the bottom
Name:	Fiero 013-resized.jpg
ID:	7141   Click image for larger version.
Name:	Garage 002-resized.jpg
ID:	7142   Click image for larger version.
Name:	Fiero 004-resized.jpg
    Sep 2006
    I have tried everything everyone has suggested. Still having the same problem.
    I have exchanged e-mails with a fellow that deals with the LS4 and Front Wheel Drive Impalla SS. He said with out a doubt our problem is that we need to turn off the "Differential Score Abuse". He went on to say that has to be turned off regardless of what else I have disabled. EFI Live has nothing called "Differential Score Abuse". Is this something like a patch that needs to be applied to the software? Can Paul help with this? I sure hate to have to purchase HP Tuner to get this customers car running. I'm lost. You guys have any more suggestions?
  9. #19
    Aug 2008
    Thats a very clean install!
    FLASHSCAN V2 & AUTOCAL
  10. #20
    Sep 2006
    Quote Originally Posted by GAMEOVER View Post
    Thanks. That's an older picture. It looks even better now but I haven't taken any pictures lately. To focused on trying to find answers to this throttle problem.
  1. This one is for Ross and Paul
    By bballer182 in forum FlashScan V2 BB Logging
    Last Post: June 21st, 2008, 10:34 AM
  2. ETC question for Ross/Paul (and anyone else who knows ;))
    By turboberserker in forum Custom Operating Systems
    Last Post: October 8th, 2006, 04:17 AM
