Results 11 to 20 of 21
Thread: I give up.
    Jul 2008
    Isn't Marcin (RedHardSupra) in Charleston, SC?
    I don't know if he does trucks..but is there anything he doesn't know?
    Isn't that just a few hours drive at most?
    Devil, try pulling the tune out of your Z06 and let us know. Since you can grab the TCM file from your truck Im thinking there's something wired to the ECM harness thats messing up your comms. Have you tried disconnecting your HU and any adapters it uses? Know its a pain, but even without fuses/power they can still mess stuff up. Ive spent 45+ min before on the side of the road trying to get a tune to flash back in.
    Jun 2010
    I had a similar problem. I asked for help nicely and followed everyone suggestions. It was the firmware in my scan tool. Works perfect now!
    I suggested that you use a battery charger, while reading. Have you done that?
    Custom Tuning Services
    Devil_Z,
    Do you have V7.5.6.125 and V8.1.2.105 installed...?
    Did you flash 2.6.35 specifically from the V8.1.2.105 install...?
    (there are several beta 2.6.35 firmware files... each time you install a new V8 software build you need to flash in the new 2.6.35)
    Junior Member NMDuramax's Avatar
    Feb 2010
    I had this same problem when I first tried to do my download. I have a 2005 LLY too and I learned that hard way after i tried several times to do the same thing you are. Neither EFI Live or the GM Tech II will do anything with the databus unless the "15 amp Radio" fuse is pulled under the hood on the drivers side with an aftermarket stereo that has its own bus. After I did that I have had no issues doing downloads or tunes as long as I pull that fuse.
    2005 Silverado 4x4 Duramax DSP2
    4 inch straight exhaust, fuel rail shim kit, PVC re-route kit, modded intake horn, and air bag kit for towing.
    1999 Camaro LS1 6 speed, torquer 3 cam, LS6 intake, MAF delete, and M9 rear w/ 4:10's.
    That is the power draw issue that is remedied with the battery charger. Which can also be caused by poor battery charge, hvac fan, etc.
    Senior Member Racehemi's Avatar
    Nov 2005
    I had some really weird issues on an LLY that once had a BullyDog tune installed.... sounds like you need to have someone with a TechII reflash it using a fresh calibration file. A Full Flash using the V2 may work also but you will need the stock tune.
    04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
  9. #19
    Quote Originally Posted by NMDuramax View Post
    Is this a 2005 specific thing? I've never pulled any fuses at all in my 04 LLY (now LBZ) and I've never even had the slightest problem reading, flashing, etc with with my V1, V2 or Tech2.
  10. #20
    Jan 2008
    from what i've heard it kind of a hit n miss type of deal. some it's a problem and some it's not...
  1. I give in....I have reached my frustration point
    By chevroletfreak in forum Gen III V8 Specific
    Last Post: August 9th, 2009, 08:10 AM
  2. Having Trouble. Please give advice
    By ntrimm in forum Gen IV V8 Specific
    Last Post: May 15th, 2009, 01:13 AM
  3. This is a professional tune?? If so I give up.Let me know whats wrong
    By BrianC98Z28 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 19th, 2008, 07:33 AM
  4. Don't Give up on us Gassers !
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 21st, 2006, 01:10 AM
