EFILive Support (problems with your FlashScan):
showthread.php?14547-EFILive-Support
Where to send your V2 for repairs (if your FlashScan is broken):
Return Merchandise Authorization (RMA)
What to Tune Steps:
showthread.php?t=7867
showthread.php?t=7866
Summary Notes:
showthread.php?14188-Summary-Notes
Calc.VET and Calc.MAFT:
Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
Calc-MAFT-correcting-VE-and-calculating-MAF-(in-single-log)-(reverse-of-Calc-VET)
CALC-VET-Summary-Notes
Marcin Pohl's Tuning Experiments and Discussions:
Tuning Tools, Writeups, and Experiments
Difference-between-Direct-and-Learned-Idle-Airflow:
Configuring units in tunetool:
Configuring-the-calibration-display-units
Part-throttle-shift-table-conversion
Can-you-go-from-C-to-F-degrees
Configuring units in scantool (set MAP to Metric):
Scan-tool-match-tune-tool
Runway-highlighting-not-tracking
Fixed point quantization (rounding) in tune file:
showthread.php?p=33495
showthread.php?t=5856
Configuring V2 for BBL:
showthread.php?t=10714
Updating V2 Firmware:
showthread.php?t=9375 posts #9 and #10
showthread.php?t=10014
showthread.php?t=10304
showthread.php?13191-Help-updateing-bootblock-from-V2.04.72
showthread.php?13906-Need-help-getting-my-scantool-tuner-working
V2 LED meanings:
showpost.php?p=90297&postcount=22
Calibrating V2 analog inputs (only if your wideband does not have serial comms):
showthread.php?t=4593
Engine Oil Pressure (requires OPS wired to PCM rather than IPC):
showthread.php?14605-Oil-pressure-PID see post #6
Fuel Pressure Sensor tutorial:
showthread.php?t=3661
VVE Setup Tutorial (E38):
showthread.php?t=8961
DSP5 Switch Selectable Tune (Duramax):
showthread.php?t=3689
Scripts:
showthread.php?p=89039#post89039
showthread.php?p=89090#post89090
Gen III V8 Engine Management Primer:
http://carprogrammer.com/Z28/PCM/LS1/Holden_LS1.pdf
GM Mode 6 Information:
http://service.gm.com/gmspo/mode6/index.html
GM TIS Calibration Information:
http://tis2web.service.gm.com/tis2web
OBD-II Information:
http://en.wikipedia.org/wiki/Table_of_OBD-II_Codes
http://www.epa.gov/obd/questions.htm
OBD-II Diagnostic Trouble Codes (DTC's):
http://www.ls2.com/forums/showthread...rd_Diagnostics
http://www.gearchatter.com/
http://www.stengel.net/diccodes.htm C5 DTC codes
Replacing a PCM:
showthread.php?t=5958
Parts Install Tutorials:
http://www.ls1howto.com/
http://www.installuniversity.com/ins...sity/index.htm
Diagnostics using an Oscilloscope:
http://www.picoauto.com/automotive-library.html
http://www.autonerdz.com/cgi/yabb2/YaBB.pl
, I should have thought of linking the .pdf
