Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 74
Thread: Issues on the first day with efi live...
  1. #21
    Junior Member CIDRAUGHN's Avatar
    Mar 2011
    I have the flashing figured out on another computer, and the first two as well after completely reloading the software. However, I am still getting the same message when attempting to read the stock file on my first truck. Im wondering if my ecm isnt supported in this release, but the other truck that i have had success with has the same build date as mine. Maybe the SSR isnt returning it to stock?
    06 Dodge RCLB 2500 5.9L Hamilton, Maxxspool, Wicked Diesels, Bullseye Power, Industrial Injection, South Bend Clutch, Amsoil, K&N, ARP,EFILive, T&C Diesel, ATS, GDP...
  2. #22
    Mar 2011
    The message i receive when trying to read my stock file says... "Mode not supported ($11)"
    Paul, I sent all the htx files in the trace folder when I sent them to you the first time.
  3. #23
    Dec 2007
    still the same problem here, it gets to this point:
    Executing: C:\Program Files (x86)\EFILive\V8\Config\CMB_R.obj
    Virtual Machine Started
    then error message pops up "script file not supported by this software version"
    I tried a different computer, re-installed the software as Admin. ran the software as Admin. Everything updated to the latest version possible
  4. #24
    Jun 2011
    Quote Originally Posted by skneeland View Post
    I'm getting the same message (as above) now.
  5. #25
    The message "script file not supported by this software version" should only occur if/when the software version and the script file version are not compatible. For the current release, the software version is V8.2.1.155 and the script file version is 08.02.34. Follow the instructions below to verify/validate the version number of the files that have been installed (or failed to install) on your system.
    Check the version of the V8 software and make sure it shows V8.2.1. Build 155 on the main screen as per the first image below.
    Check the version of the C:\Program Files (x86)\EFILive\V8\EFILive_VM.dll file, to do that right click on it and select Properties, then select the Details page (or the Version page if you're using WinXP). Make sure the version number shows as 8.2.1.155 as per the second image below
    Check the version of the CMB_R.obj script file, to do that run Notepad and from within Notepad open the script file C:\Program Files (x86)\EFILive\V8\Config\CMB_R.obj. Make sure the version number is 08.02.34 as shown in the third image below. Close Notepad without modifying or saving the file.
    IMPORTANT: Do not attempt to modify or save the script file while viewing it in Notepad, it will corrupt the file. Only use Notepad to view the version number.
ID:	11039   Click image for larger version.
ID:	11040   Click image for larger version.
  6. #26
    Quote Originally Posted by CIDRAUGHN View Post
    Has the truck been flashed with EFILive before?
  7. #27
    Jun 2011
Name:	screen shot EFI.jpg
    Paul-
    The first two checks were ok. I couldn't get the last check complete, I've attached a screen shot.
    Josh
  8. #28
    Quote Originally Posted by chizwizdiz View Post
    Paul-
    Josh
    Change the drop down list where it says "Text Documents (*.txt)" to "All Files (*.*)".
  9. #29
    Jun 2011
    Ok, that worked, thank you. My screen displayed 08.02.33
    Thanks,
    Josh
  10. #30
    Thanks,
    Josh
    I'm not sure how the script file got to be version 08.02.33, the installer should have installed version 08.02.34.
    To force the installer to install the latest files, delete the entire V8 installation folder
    C:\Program Files\EFILive\V8 (or C:\Program Files (x86)\EFILive\V8 on 64 bit Windows) and then re-run the installation.
    Then re-check the version of the CMB_R.obj script file, it should be 08.02.34
  1. New to EFI, and having Laptop issues
    By millerman04 in forum General
    Last Post: August 29th, 2010, 04:49 PM
  2. lc-1 serial to efi-live issues
    By Jakes4321 in forum General
    Last Post: January 25th, 2010, 11:15 AM
  3. Efi live class at efi university
    By Robbie The Wrench in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2008, 02:25 PM
  4. New to EFI Live
    By Whitetail Addict in forum Lounge
    Last Post: August 25th, 2008, 06:15 AM
  5. New to EFI Live and RR
    By wickedred in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 3rd, 2007, 04:28 AM
