The trace file did not show any attempt to connect/scan any controller. Can you please supply me with some error message or description of what is not working?Sorry if you've reported it before, if there is a post that you've already made about it, just link me to that post.
Can you post a screen shot of the OS not showing correctly? And a trace file that you saved from the EFILive Control Panel after displaying the OBD info.
For V7 only:
The sequence number won't increment unless you are saving a completely new file that was just recorded. If you open a file and then do "Save As" (any number of times) it will use the same name and not increment the sequence number.
That is just an unfortunate consequence of the way the V7 Scan tool was originally designed.
V8 Scan, V8 Tune and V7 Tune will (should) increment the sequence number on all "Save As" operations.
https://forum.efilive.com/showthread...-Release/page2
about half way down. I sent you an email with everything else.
03 6spd
Cannot upgrade any CME OS to CSP4. Option to upgrade is not available under the "upgrade OS" tab. Reverted back to public release software and option is available.
Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
EFI Live Cummins Beta Tester
Duramax and Cummins Tuning
423-506-7427
I just opened up three different CME OS's (one a C&C the other two pickups) and the upgrade option is showing. The only thing I can think of is the USB driver didn't install correctly when you upgraded, I think the upgrade option doesn't show unless V7 can talk to a V2.
re-installed the beta software and now it is there. Must have been the drivers.
423-506-7427
Phew! Cheers.
Ok, it was me that failed...
my filename was 12212156_0007.tun
and when I did Save As, the new filename was 12212156_0007.ctz
and this is why the _0007 was not incremented to _0008 (because the filename/extension is different);
now after saving as _0007.ctz, when I do Save As again, I now see the next increment _0008 (with the .ctz extension), and now the increments work properly.
See, it was me --><-- .ctz
