BB Logging beta update: April 26, 2008
IMPORTANT
IF YOU HAVE NOT ALREADY DONE SO,
YOU MUST UPDATE FLASHSCAN'S BOOT BLOCK TO V2.05.08(0426)
BEFORE
YOU ATTEMPT TO UPGRADE THE FIRMWARE TO V2.05.16 OR LATER.
Download here:
http://download2.efilive.com/Softwar...il_26_2008.zip (19Mb)
This download includes and supersedes all previous BBL beta downloads.
Please read the Readme_First.pdf file included in the zip file.
It has been revised for this release and contains important information about how to upgrade the boot block in your FlashScan and/or AutoCal devices.
Make sure you update your FlashScan (and/or AutoCal) firmware and boot block using the latest *.ffw files from the \Program Files\EFILive\V8\EFILive_Hapi folder\.
Please read the first posts in the March 20, March 26, April 07 and April 14 releases so that you are aware of the previous versions' pre-requisites.
http://forum.efilive.com/showthread.php?t=7566
http://forum.efilive.com/showthread.php?t=7643
http://forum.efilive.com/showthread.php?t=7747
http://forum.efilive.com/showthread.php?t=7809
1 Attachment(s)
BBL log file error: Cannel count is 0, cannot load file
Hi Guys,
The good news first.... The TechEdge serial data looks excellent, thanks a lot for getting this added so quickly.
Now on to the "not so good" news. I just tried 2 BBL sessions and both log files come up with the error above. Opening the logs in a Hex editor shows the data is different from the old logs, with no delimiter data between some of the Meta data details.
During the upgrade I formatted the config file system and copied over the new files. I've checked my PID count and it is only 17.
Sample file is attached....
Update: I just went through the log file with the Hex editor and added in a few "0D 0A" characters at the right spots and the file opens cleanly. The addresses are.....
0x042C
0x0443
0x0450
0x0596
