I'm not sure if this has been mentioned, but the ability to adjust and turn off pre and post injection would be nice.
Thanks, I am new to EFI and have not had a chance to look at the features yet. When 2005 is avaliable I am eager to dive in.
You can download the software now, download a stock Cummins file and start playing with the software and seeing how it works.
Then you will familiar with it when it comes out for you guys.
OK thanks
sorry if this was mentioned already, If it was I just missed it. I'm passing this along from cumminsforum
the ability to change what a/c psi the fan clutch engages and disengages. It would help out with troubleshooting the fan clutch a lot, and might make the a/c in the dodges work better
thanks
JT
How about a unit that I can plug into my nav deck and will dispaly my gauges on it and or switch level?
Anything new on the with the High idle and cruise control? I really miss that feature.. It's odd with the Smarty anytime you load a file into a truck, and return that truck to stock, the high idle feature stays working, unless you flash it with a clean base tune.
For now you'll need a base tune with the high idle enabled, or use a Starscan (dealer) to enable it and save that as your base tune.
