Page 12 of 15 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 141
Thread: 06-07 5.9L Feature Request List
  1. #111
    May 2012
    I'm not sure if this has been mentioned, but the ability to adjust and turn off pre and post injection would be nice.
    2005 Dodge 3500, 60HP Injectors, BD CAC, BD Killer B Turbo, BD TC and Valve Body.
  2. #112
    Junior Member gneal02's Avatar
    Jul 2011
    Quote Originally Posted by 2005Dodge View Post
    That's been available since EFI started with the Cummins.
  3. #113
    May 2012
    Thanks, I am new to EFI and have not had a chance to look at the features yet. When 2005 is avaliable I am eager to dive in.
  4. #114
    Senior Member DODGE74's Avatar
    Oct 2011
    You can download the software now, download a stock Cummins file and start playing with the software and seeing how it works.
    Then you will familiar with it when it comes out for you guys.
    06 QCLB, DRW
    Single pump
    Single turbo
    EFILive 772hp 1398tq
    [email protected]
  5. #115
    May 2012
    OK thanks
  6. #116
    Jul 2012
    sorry if this was mentioned already, If it was I just missed it. I'm passing this along from cumminsforum
    the ability to change what a/c psi the fan clutch engages and disengages. It would help out with troubleshooting the fan clutch a lot, and might make the a/c in the dodges work better
    thanks
    JT
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
  7. #117
    Member Motorzane's Avatar
    Jun 2011
    Quote Originally Posted by Wheelz View Post
    thanks
    JT
    Just fan control in general would be great. I tow heavy and 215-220 deg are not what I like to see.
  8. #118
    Aug 2012
    How about a unit that I can plug into my nav deck and will dispaly my gauges on it and or switch level?
  9. #119
    Dec 2012
    Anything new on the with the High idle and cruise control? I really miss that feature.. It's odd with the Smarty anytime you load a file into a truck, and return that truck to stock, the high idle feature stays working, unless you flash it with a clean base tune.
  10. #120
    Jun 2011
    For now you'll need a base tune with the high idle enabled, or use a Starscan (dealer) to enable it and save that as your base tune.
  1. Feature Request List
    By skneeland in forum Cummins 5.9L
    Last Post: June 13th, 2011, 04:54 PM
  2. Feature request v2
    By ringram in forum General
    Last Post: July 9th, 2008, 04:44 PM
  3. Feature request
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2007, 11:05 AM
