Can you post a log file...
did you select the pids SAE.WO2S11 and SAE.WO2S21 to log (because EFILive might have the channels swapped)...?
I have can make a calc pid to show AFR (IIRC, AEM assumes AFR is 14.57).
I'm not sure. But, I don't believe that the 7.5 software was updated to read the 30-0333.
That makes sense :)
I was just using one (and the readings looked correct, just lambda values instead of AFR, compared to the AEM's gauge.) I forget which, was using a different machine I don't have handy at the moment, but pretty sure I was using WO2S21. Will make some new logs and post soon.
It was WO2S11, here's the file, having some trouble importing the BBX file into the v8 scan tool, when I pick the trans controller, AEM UGEO Bank 1 isn't an option in the "select controllers" menu, and when I select it from the drop down, v8 clears the tune file, so that appears to be a bug in the current release.
Attachment 20811
I see your pid SAE.WO2S11 behaving like wideband lambda... it is usually about 0.99 and dips down to 0.6 or so.
Yup, that's working; did you have a calculated PID to convert the lambda value to AFR you'd be willing to share?
I've not touched my calc_pids.txt.
Thanks!
