I had that feeling guess I'll do one analog and the other serial and compare the 2
What about the SM-AFR. I was thinking about buying two.
I sent them a message to find out. Will let you know when I hear.
I was just going to start a thread with the same question. I just received my LM-2 and already have a LC-1 connected serially.
The LM-2 is mainly for other vehicles, but for kicks I wanted to hook it up along with my LC-1 so I could monitor both banks.
Im guessing I need to make a molex ---> RJ11 (Telephone) to connect the LM-2 serially by itself, then a 2.5mm to 2.5mm connector for when I want to run it with the LC-1?
How does one configure the V2 to see both widebands with one input?
Hi Sam,
Innovate widebands know how to serially daisy chain...
remember you need:
- Terminator plug goes into WB1 SERIAL-IN,
- WB1 SERIAL OUT goes WB2 SERIAL IN,
- WB2 SERIAL OUT goes thru null modem bender to FSV2.
See post #3 here: Setting-up-a-FSV2-from-scratch
Thanks Joe, I just didnt know how the V2 was supposed to see each wideband individually.
Googling 'Null modem bender' doesn't look like the TAQ cable used to look. I cant get a hold of him about buying a cable, is there someone else that sells something or has some instructions for making your own?
See this thread: serial-port-cable-that-goes-to-v2
