Thanks Paul, will let ya know if we find anything. I get the same thing at instlal, shows up at build 260 file name but about says build 259.
If this is posted in the wrong thread let me know.
Can I upgrade my software from the attached picture using the links in this thread in one operation or does it have to be done incrementally?
OR
Can I continue to use my old EFI software and have my tuner as he has in the past send .tun files and convert with my old software and not bother upgrading the software?
Is the LMM DSP5 scaling issue and the 2 missing tables (B2256 and B2257) going to be fixed in a future release?
Yes but not this release.
You need to update. It's a simple process from your versions, just download the software and install.
You will need to update you firmware and bootblock within the V8 software once you update, but it's straight forward moving from the version your currently running.
Cheers
Cindy
Can I continue to use the old software yes or no?
Could you give the link for the firmware to verify I have the correct firmware build for the software. (firmware V2.07.64 Jul 2014, I assume it is this one?) The V7,V8 (in this link) update the software first then update firmware?
Is it possible to put the most current items in one place V7-V8- firmware-bootblock? I have been following these updates for quite some time and stumbled upon the firmware update or maybe just did not read all my subscribed threads carefully enough. I do have the March 12,2012 PDF instructions and will reference it again.
All the updates are in one place; the first post of this thread.
You should download and install the V7.5 and V8 software packages from the first post of this thread. Once the V8 software is installed, run the V8 EFILive Scan and Tune program and click on the [Check Firmware] button to update your FlashScan and/or AutoCal devices with the latest firmware and configuration files.
The FlashScan and AutoCal boot block has not been updated in this release.
