Awesome Fubar! Great work, should make it a lot easier for everyone to log!
Dont know if this has come up yet, but removing the intake air heater relay without throwing the associated codes, since it is useless without the intake air heater on board would be awesome.
The ability to adjust the min/max speeds the cruise control works at would be great!
I've already created the document needed to use the feature here: http://forum.efilive.com/showthread.php?t=16878
Question on dealer enabled options.
If you have certain options enabled by the dealer and then copy the stock tune, modify, and re-write will those options stay enabled?
Such as manual fast idle, door locks, B20 kit, etc?
Mine stayed.
