1 Attachment(s)
Setting up a FSV2 from scratch...
Install the latest V7 and V8 (both) software builds from here: Software-Updates-and-Installation-Help
Flash the latest bootblock/firmware into your V2:
- start V8 Scan & Tune (S&T),
- click Check Firmware,
- if the firmware needs updating you will see a button Update Firmware, click it,
- if the V2 BBx configuration needs updating you will see a button to Refresh it, click it (see Note below),
- click Ok to exit the firmware update dialog box.
Note: If you had already configured V2 BBx as shown below, then click the button you see to Refresh the V2 BBx config (see pic below), wait until the refresh is finished, and now you're done.
Note: if you have not yet configured V2 BBx config then continue here:
Insert an SD card into your FSV2 (and leave it in your FSV2 from now on).
Configure BBx for your PCM or ECM/TCM:
- goto F6: Devices,
- set File System to SD Card,
- save to file Settings.dat,
- click Program,
- click Close,
- goto F5: BBX,
- click Format Config File System (accessed via downarrow next to Program button),
- goto Scan page (see Note below),
- in the blue pane delete pidlists for ECM's other than yours,
- in the blue pane you can add new pidlists for your ECM,
- each pidlist in the blue pane can have a number of pids as shown in the green pane (to which you can add pids from the yellow pane),
- at the bottom of the green pane is a bargraph showing pid usage, do not let this turn red (too many pids selected),
- goto Tune page,
- delete any ECM's other than yours,
- if not already present, add entries for your ECM type(s),
- goto DTC page,
- checkmark the DTC descriptions you want to see,
- save to file Options.txt,
- click Program All (accessed via downarrow next to Program button), wait for it to finish,
- click Close,
- goto F8:Tools (if you have any .tun files to conver to .ctz),
- in the upper box, browse to your .tun files, and click Convert Now,
- click Close,
- exit V8 S&T.
More Info: kb_article.php?ref=6659-YAHB-3781
Note: on the Scan page, the right-hand pane is yellow, the upper-left pane is blue, and the lower-left pane is green.
This pic shows the Update Firmware window with the BBX Configuration Refresh button:
Copying tune files to V2...
First, from the V7 tunetool, save your .tun files as .ctz (this is now the tune file extension type).
Then copy those .ctz files to your V2:
- start V8 EFILive Explorer (EE),
- goto Data Files tab,
- click Home,
- upper pane (PC): locate the .ctz files,
- lower pane (V2): go into the Tune folder,
- copy/paste/drag the .ctz files from the upper pane (PC) to the lower pane (V2),
- exit EE.
Setting up V2 for serial wideband...
- goto F6: Devices,
- goto Logging page,
- checkmark Automatically select ALL digital (serial) PIDs <-- do this for serial wideband
- checkmark Automatically select ALL analog PIDs <-- do this for analog wideband
- set Logging Speed to Fast (10-40 frames/second),
- goto Serial I/O,
- set Com Port to Wideband,
- set Wideband Type to your wideband,
- click Program,
- click Close,
- exit V8 S&T.
More Info: kb_article.php?ref=8371-TIPK-2770
When you BBL log, these serial wideband pids will be included (they occupy zero pid channels):
- EXT.WO2AFR1 and 2,
- EXT.WO2LAM1 and 2,
- EXT.WO2EQR1 and 2,
- EXT.WO2ST1 and 2.
( these are the wideband pids, so do not log the analog wideband AFR/BEN pids )
Newer V8 allows semiautomated BBL config update...
After you've done post #1 above least once, the newer V8 interface will show you what requires updating regarding BBX, you just tell it to proceed.
