Known issues with the Novemeber 2015 Public Pre-Release
Currently known issues and possible workarounds for the November 2015 Public Pre-Release of the EFILive Software and Firmware
Download the current/stable release software here: http://www.efilive.com/latest/cat/download-efilive
Download the public pre-release software here: https://forum.efilive.com/showthread...ic-Pre-Release
Public pre-release software versions:
- Software: V7.5.7.297
- Software: V8.2.2.288
- FlashScan/AutoCal firmware: V2.07.93
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
The firmware date for FlashScan and AutoCal shows up as N/A instead of Nov 14, 2105.
Workaround:
None.
Issue 3:
The "Bins" folder setting in the V7 scan tool Edit->Properties->[Folder] tab page is not being saved/restored across application restarts.
Workaround:
Manually edit the EFILive V7.5 registry setting: \\HKEY_CURRENT_USER\Software\EFILive\V7.5\Properti es\Dir->Bins
Will be fixed in the next update.
Issue 4:
Error $0506 when reading an E80 controller in standalone mode with either FlashScan or AutoCal.
Workaround:
Use pass-thru reading for E80.
