Tried all of the base tunes in the library. None seem to be right, i.e. loss of engine brake and turbo stuck at 50%. Any help would be greatly appreciated.
Tim Zapoluch
Tim Zapoluch
Every possible stock tune is available via links in this thread.
https://forum.efilive.com/showthread...k-tune-library
But you need to know what would have been in the ECM to begin with, if that is already been flashed over then you need to do this.
Look at the label on the ECM and it should have printed on there an E/C number, it will look something like DO90002.20 , DO90007.16. You will find the files in the links have that in the name as well, match that up and you'll be good to go.
