1 Attachment(s)
March 2016: EFILive Pre-Release
Please download and install both the V7.5 and V8 software packages.
Both the V7.5 and V8 software were updated in this release, you must update both software packages.
Release Notes: Updates
- Both V7.5 and V8 installation files above have been re-signed with the correct SHA256 certificates and should no longer be flagged by Windows as having corrupt or invalid signatures.
- The calibration definition for E78 OS 12654014 has been updated to prevent the "Invalid floating point" error. Download the attached 12654014.calz file and save it into the folder: C:\Program Files (x86)\EFILive\V7.5\Calibrations\E78, overwrite the existing file.
Known IssuesPlease post new issues, questions or clarifications (large or small) in this thread.
As new issues are verified they will be posted in the
Known Issues thread.
Version Numbers:
After installing the latest release you should have the following software, boot block, firmware versions installed:
EFILive V7 software: V7.5.7 Build 303
To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 294
To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.07 (Feb 07, 2014)
To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.97 (Mar 04, 2015)
To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
The EFILive Development Team
