Results 1 to 7 of 7
Thread: Known issues with the March 2016 Pre-Release
    Default Known issues with the March 2016 Pre-Release
    Currently known issues and possible workarounds for the March 2016 Pre-Release of the EFILive Software and Firmware
    Download the March 2016 pre-release here: https://forum.efilive.com/showthread...ve-Pre-Release
    Download the public stable-release here: http://www.efilive.com/latest/cat/download-efilive
    Pre-release software versions:
    • Software: V7.5.7.303
    • Software: V8.2.2.294
    • FlashScan/AutoCal firmware: V2.07.97
    Issue 1:
    Workaround:
    None.
    It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
    Issue 2:
    When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
    Workaround:
    EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
    Issue 3:
    "Invalid floating point" error when opening E78 OS 12654014 tune files.
    Workaround:
    Download 12654014.calz and save it into the folder: C:\Program Files (x86)\EFILive\V7.5\Calibrations\E78, overwrite the existing file.
    Lifetime Member Road's Avatar
    Feb 2015
    I don't know if the issue is on me or EFI but when I download 7.5 or 8 I get a error: The signature of this program is corrupt or invalid. And find no way around the error to install it.... Thanks
    Never mind it's me. If it happens to you go to your downloads and right click the download and select run anyways.
    Quote Originally Posted by Road View Post
    Which version of windows are you using?
    I highly recommend downloading the files again. If you attempt to install a file with a damaged/faulty signature then you may be installing a compromised version of EFILive that may contain malware, virus, trojans or just plain corrupted. The whole reason we digitally sign the EFILive installation files is to detect any modifications whether malicious or accidental to the downloaded files while they are en-route from EFILive to your PC.
    If the signature is not correct DO NOT INSTALL the software. Re-download it and try again.
    Feb 2015
    I was windows 7. I downloaded it 3 times and got the same error everytime. It was different type than the normal one that windows 10 gives. I will re-download it and see what happens.
    Feb 2015
    Just downloaded it on my windows 10 computer and getting the same message.
Name:	signature error.png
    After some investigation, turns out Microsoft have brought forward their deprecation of SHA-1 certificates and, as of Jan 1, 2016 require installers to be signed with SHA-256 certificates.
    https://www.globalsign.com/en/blog/m...igning-policy/
    EFILive will need to re-issue the downloads with a SHA-256 certificate. We'll do that asap.
    Ah yes, found this out at work last week. Had to update all the servers with SHA256 certs as we were using SHA1. Now I know there's an actual reason we did it!
  1. Known issues with the Novemeber 2015 Public Pre-Release
    Last Post: November 17th, 2015, 09:50 PM
  2. Known issues with the September 2015 Public Pre-Release
    Last Post: September 11th, 2015, 10:46 AM
  3. Known issues with March 2015, Release Candidate 1
    Last Post: April 10th, 2015, 10:03 AM
  4. Software issues with build 99 pre release...
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 18th, 2010, 04:25 AM
