Attachment 18460
I been having issue with getting my AFR connected for DATA Logging. Its a AEM 41-4900. Can any one help please.
Attachment 18460
What is the issue...?
Code:# ==============================================================================
# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code System Abbr Description
>>> delete this line:
AFR_AUEGO1 W02-Analog "AFR_AUEGO1" "AFR_AUEGO"
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-001
AFR 8.5 18.0 .2 ({EXT.AD1}*2.3750)+7.3125
>>> add a blank line here:
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
>>> change "AFR,V" to "AFR":
CALC.AFR_AEUGO1 F001 CLC-00-001 "AFR,V" "W02-Analog" "AFR_AEUGO"
>>> add at least 2 blank lines here:
joecar
It's not showing up in PID list to be selected. I save in the 7.5v user configuration
Does the AEM UEGO 41-4900 have a serial comms output...?
Post your current calc_pids.txt file.Quote:
Originally Posted by Mouth
In the scantool, on the pids tab, click twice on the column heading "Parameter" (i.e. the right most column)(on it's heading/title) to sort the pid list by this column... then scroll down while looking at this column until you see your calc pid...
then on this pid do rightclick->More Info to see what other pids you may need to select.
If you can get it connected to V2 using serial comms, you will be better off (for a number of reasons):
joecar,
No it do not have a serial comms
