Results 1 to 10 of 11
Thread: What kind of serial output is used for V2?
    Default What kind of serial output is used for V2?
    I am in the process of revamping our dyno and wideband setup. The wideband is a high end unit that puts out a serial output that is CAN based. I am trying to figure out what kiIt nd of signal the V2 is using as there are three types of serial outputs.
    Can it read a .dbc format? Attached is the data on the unit. I would prefer to stick with CAN based control as some of the new dynos are using the same protocol.
    Need some clarification.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    FlasScan interfaces with wide band controllers using an RS232 serial interface.
    Currently we support:
    Innovate LC-1, LM-1, LM-2
    PLX
    JAW
    TechEdge
    FJO
    AEM UEGO
    Each of those devices outputs a completely unique serial protocol.
    FlahScan has been coded to handle each of them. Adding a new one should not be too difficult.
    I'd just need to know the exact byte by byte description of the serial data format.
    Plus the serial baud rate, start/stop/parity bits etc.
    We can't easily do the CAN integration because the integration would need to be on the vehicle's CAN bus (our only CAN input) and I don't think it would be wise to start transmitting AFR data on the vehicle's CAN bus. For one, most vehicles use one or more of CAN ID's 0x7E0..0x7EF, some of which the AFR document stated must be reserved for the AFR devices.
    Nov 2006
    Are'nt the new GM's equipt with WBO2s instead of NBO2s?
    LC-1 WBO2
    Quote Originally Posted by mr.prick View Post
    I believe they are going that way, but I have not heard of any (that we support) using wide band O2's yet.
    But just 'cause I haven't heard, doesn't mean it isn't so. (was that a triple negative?)
    Does this mean anything;
    Communication is 38400 baud, 1 stop bit, 8 data bits, 1 stop bit and no parity?
    Howard
    1-954-703-5560
    See pages 6-8. I think it what you may need. If so what is involved in setting it up. These guys make OEM development WB's and they are interested in being compatible with EFI Live input as well.
    Howard
    1-954-703-5560
    Nov 2006
    which one do you have?
    The serial pin outs are on page 16.
    V2 RJ12 input
    1 <---> Tx Data
    2 <---> Rx Data
    5 <---> Ground
    FlashScan to LC-1 and LM-1 Serial Cable Diagrams
    LC-1 WBO2
    The unit is the AFM1500. It sounds fairly straight forward as to the wiring into the RJ12 plug. I was more concerned about the protocol data crap that needs to be configured. I am lost with that stuff!
    I got a e-mail into Paul to figure out how this is all done.
    Howard
    1-954-703-5560
    Quote Originally Posted by Redline Motorsports View Post
    Howard
    I'm confident we can add support for it. At the very least, support enough to display the status and AFR or Lambda readings.
    Nov 2006
    This would be a nice addition to the serial WBO2 support for shop tuners
    and hardcore hobbyists.
    LC-1 WBO2
  1. What kind of changes are needed to run speed density
    By bwelch in forum Gen III V8 Specific
    Last Post: March 2nd, 2011, 02:24 PM
  2. Anyone using serial output from FJO WB?
    By 67SS509 in forum General
    Last Post: November 26th, 2009, 12:43 PM
  3. what kind of pw do you guys run?
    By hot-dog in forum Diesel
    Last Post: February 10th, 2009, 02:38 PM
  4. adapter to use LC-1 serial output
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: October 3rd, 2007, 10:59 AM
