Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 84
Thread: EFILive Version 8 (Black Box Logging) is now available
    Yap Yap... Been using efilive with W7 since 7000 and the only issue i had was minor that the arrow keys seemed to be "stuck" but after a reinstall... everything flawless!
    Same here, just thought Id post it so anyone can make it work the first time. Used it first on b7000 too now onto b7100, didnt bother to make V8 beta work on W7 as I was using Vista as my test OS to keep a backup copy of V8 guaranteed to work.
    Oct 2006
    Is this going to replace V7.5 completely soon ?
    2006 Trailblazer
    Feb 2009
    Hello,
    I'm trying to set up my pids with the new software and I get this....see attached.
    I must be missing something somewhere.
    Can anyone point me in the right direction, everything else seems fine.
    Thanks,
    Brad
    99 Firebird Formula, M6, LS6 intake, headers, catback, lid, BRE cam.
    EFI V2, V7.5.5 (Build 149)
    V8.1.2 (Build 142)
    Boot Block 2.07.01 Oct 14, 2010
    Firmware 2.07.05 Jan 29, 2011
    LC-1 with serial cable
    COS 5
    Quote Originally Posted by bmax View Post
    Hello,
    Thanks,
    Brad
    It means that the PCM you are using does not support that particular PID.
    In the short term, you need to remove the PID from the list of selected PIDs in the BBL setup software and re-program the FlashScan with the new PID selection.
    In the long term... it is a DMA PID which is supported/unsupported depending on the operating system number of the PCM. It may be that we have not added support for that PID for the particular operating system of your PCM.
    Can you send the OS number of your PCM? Use the FlashScan device, menu option: F2->F2->F1 to get the operating system number.
    Nov 2006
    So some of the PIDs are not supported for BBL right now?
    LC-1 WBO2
    May 2009
    In the Flashscan Menu Items section, I can only see LS1, LS2, LB7 and LMM options (all "sample"). I am looking for the LBZ,AL6 PID list. How do I get this, or is this not possible on this release?
    2007 Chevy 2500 Classic, LBZ Duramax, 4X4, LT3, CCSB Mods so far: Nicktane Fuel Filter, EFILive V2, PAC AAI-GM24 Aux Stereo Input (great for connecting the MP3 player).
    Paul has set BBL up now to be 100% user defined, as in you need to open up S&T then add the proper vehicle (in your case LBZ and AL6). Once you have that setup, click on it then add PIDs to the lower left pane!
    Quote Originally Posted by dinorex44 View Post
    In the blue section, right click an Unused row and select Properties. In that Properties screen you can select which controller you want to configure. You can delete/overwrite the sample ones if you want.
    Each item that you set up in the blue section, corresponds to an item in FlashScan's/AutoCal's PID selection menu.
    Remember to use the [Program] button to program the changes back into FlashScan/AuotCal.
  9. #19
    dinorex, for example, look at post #210: showthread.php?p=94515#post94515
  10. #20
    Paul, is there a way to set the non-custom precision...?
  1. EFILIVE V8 Black Box Logging Questions - Imperial units?
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: May 13th, 2009, 01:21 PM
  2. V2 Black Box Logging
    By Blacky in forum FlashScan V2
    Last Post: November 4th, 2007, 10:51 PM
  3. V2 black box logging?
    By articSS in forum FlashScan V2
    Last Post: September 23rd, 2007, 04:57 AM
  4. is black box logging available on v2 yet ?
    By imtduncan in forum General (Petrol, Gas, Ethanol)
    Last Post: August 18th, 2007, 12:11 PM
  5. Black Box Logging Bug ?
    By Ninety8C5 in forum General
    Last Post: July 24th, 2006, 02:31 PM
