Results 1 to 3 of 3
Thread: COS 5 question
    Feb 2009
    Default COS 5 question
    Hey guys,
    If I get my VE table spot on, can I then adjust my commanded (B3647) with out having to re do my BENs?
    Or does it require tweaking the VE table again?
    Also any pointers for setting up A0007 would be appreciated.
    Thanks in advance.
    Brad
    99 Firebird Formula, M6, LS6 intake, headers, catback, lid, BRE cam.
    EFI V2, V7.5.5 (Build 149)
    V8.1.2 (Build 142)
    Boot Block 2.07.01 Oct 14, 2010
    Firmware 2.07.05 Jan 29, 2011
    LC-1 with serial cable
    COS 5
    Yes, you can now modify B3647 and B3618 and your ben's will remain the same.
    For TPS VE see attachment.
    More info on COS5:
    showthread.php?t=2599
    showthread.php?t=2270
    Feb 2009
    Awesome,
    Thanks Joe
    V8.1.2 (Build 142)
    COS 5
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 11:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
