Results 1 to 10 of 18
Thread: Knock sensor wiring
    Oct 2006
    Default Knock sensor wiring
    I have finally finished installing an LS3 into my VY commodore. The question I have is in relation to the knock sensor wiring for the ls3 knock sensors. in the tune tool we get this description.
    The PCM can be used with two types of knock sensors, this parameter allows you to select which type of sensor is fitted to the engine.
    The standard LS1 sensor is a resonant type, these sensors are connected like so -
    Sensor Bank #1 - J1,pin56
    Sensor Bank #2 - J1,pin11
    If the engine is fitted with flat response sensors (like the LS2 uses), then the connections are like so -
    Sensor Bank #1 GND - J1,pin49
    Sensor Bank #1 Signal - J1,pin09
    Sensor Bank #2 GND - J1,pin50
    Sensor Bank #1 Signal - J1,pin10
    Only the following values may be entered into this table:
    - Resonant (LS1)
    - Flat Response (LS2)
    Are the two grounds already wired from J1 pin 49 & 50 or do we need to add these wires ? Is J1 the red or blue connector?
    Thanks in advance Mick
    The Tremor at AIR
    Nov 2006
Name:	Cam_Crank_Knock Sensors.gif
    Can the LS1 controller use LS2 style KR sensors?
    I've only heard of people re-tapping the LS2 KR threads to use LS1 sensors.
    But maybe that's because it's easier than adding the pins.
    c1 (blue) 49 & 50 and c1(blue) 9 & 10, are not used on the LS1.
    C1 is probably J1.
    '98-'02 PCM Pin Assignments
    2002 Fbody
    PCM connector C1 (BLUE)
    Pin Wire Color Circuit No. Function
    1 BLK 451 PCM Ground
    2 LT GRN 1867 12 Volt Reference- CKP Pin "C"
    3 PNK/BLK 1746 Fuel Injector 3 Control
    4 LT GRN/BLK 1745 Fuel Injector 2 Control
    5-7 -- -- Not Used
    8 GRA 596 5 Volt Reference TPS Pin "A"
    9-10 -- -- Not Used
    11 LT BLU 1876 KS [2] Signal Rear Sensor Pin "B"
    12 DK BLU/WHT 1869 CKP Sensor Signal Pin "A"
    13-16 -- -- Not Used
    17 DK BLU 1225 Transmission Fluid Pressure Switch Signal B Pin "R"
    18 RED 1226 Transmission Fluid Pressure Switch Signal C Pin "P"
    19 PNK 439 Ignition 1 Voltage
    20 ORN 340 Battery Positive Voltage
    21 YEL/BLK 1868 Low Reference CKP Pin "B"
    22 -- -- Not Used
    23 GRA 720 Low Reference Fuel Level Sensor (Factory)
    24 -- -- Not Used
    25 TAN 1671 HO2S Low Signal [Bank 2 Sensor 2]
    26 TAN 1667 HO2S Low Signal [Bank 2 Sensor 1]
    27 -- -- Not Used
    28 TAN/WHT 1669 HO2S Low Signal [Bank 1 Sensor 2]
    29 TAN/WHT 1653 HO2S Low Signal [Bank 1 Sensor 1]
    30-31 -- -- Not Used
    32 GRA 48 CPP Switch Signal (Manual Trans.)
    33 PPL 420 TCC Brake Switch Signal (Auto. Trans)
    34 ORN/BLK 434 Neutral Safety Switch Signal
    35 -- -- Not Used
    36 BLK 1744 Fuel Injector 1 Control
    37 YEL/BLK 846 Fuel Injector 6 Control
    38-39 -- -- Not Used
    40 BLK 451 Ground
    41 -- -- Not Used
    42 DK GRN 335 Low Speed Cooling Fan Relay Control (Primary fan)
    43 RED/BLK 877 Fuel Injector 7 Control
    44 LT BLU/BLK 844 Fuel Injector 4 Control
    45 GRA 474 5 Volt Reference (A/C Refrigerant Pressure Sensor) (Factory)
    46 GRA 474 5 Volt Reference (Fuel Tank Pressure Sensor) (Factory)
    47 -- -- Not Used
    48 GRA 416 5 Volt Reference (MAP Sensor) Pin "C"
    49-50 -- -- Not Used
    51 DK BLU 496 KS [1] Signal Front sensor Pin "A"
    52 -- -- Not Used
    53 BLK 407 Low Reference (Transmission Temperature Sensor) Pin "M"
    54 BLK 407 Low Reference (MAP Sensor Ground) Pin "A"
    55 -- -- Not Used
    56 -- -- Not Used
    57 ORN 340 Battery Positive Voltage
    58 DK GRN 1049 PCM Class 2 Serial Data
    59 -- -- Not Used
    60 BLK 452 Low Reference TPS Pin "B"
    61 PNK/BLK 632 Low Reference (Camshaft Position Sensor) Pin "B"
    62-64 -- -- Not Used
    65 PPL 1670 HO2S High Signal [Bank 2 Sensor 2]
    66 PPL 1666 HO2S High Signal [Bank 2 Sensor 1]
    67 -- -- Not Used
    68 PPL/WHT 1668 HO2S High Signal [Bank 1 Sensor 2]
    69 PPL/WHT 1665 HO2S High Signal [Bank 1 Sensor 1]
    70 BRN 1174 Oil Level Switch Signal
    71-72 -- -- Not Used
    73 BRN/WHT 633 CMP Sensor Signal Pin "A"
    74 YEL 410 ECT Sensor Signal Pin "B"
    75 -- -- Not Used
    76 BLK/WHT 845 Fuel Injector 5 Control
    77 DK BLU/WHT 878 Fuel Injector 8 Control
    78 -- -- Not Used
    79 GRA or WHT 587 or 687 Skip Shift Solenoid Control (M/T) or 3-2 Shift Solenoid Control (A/T) Pin "S"
    80 BLK 407 Low Reference ECT Pin "A"
    PCM connector C2 (RED)
    1 BLK 451 Ground
    2 BRN 418 TCC Solenoid - Output - PWM Pin "U"
    3 -- -- Not Used
    4 PNK/BLK 429 Air Injection Reaction Solenoid Relay - Coil - Control
    5 -- -- Not Used
    6 RED/BLK 1228 PC Solenoid Valve High Control (Sol.A) Pin "C"
    7 -- -- Not Used
    8 LT BLU/WHT 1229 PC Solenoid Valve Low Control (Sol.A) Pin "D"
    9 DK GRN/WHT 465 Fuel Pump Relay Control [Primary]
    10 WHT 121 Engine Speed Signal- Tachometer
    11-12 -- -- Not Used
    13 WHT 85 Cruise Control Engage Signal
    14 RED/BLK 380 A/C Refrigerant Pressure Sensor Signal
    15 RED 225 Generator Turn ON Signal
    16 -- -- Not Used
    17 DK GRN/WHT 762 A/C Request Signal
    18 DK GRN 59 A/C Compressor Clutch Supply Voltage
    19 -- -- Not Used
    20 LT GRN/BLK 822 VSS Low Signal
    21 PPL/WHT 821 VSS High Signal
    22-23 -- -- Not Used
    24 DK BLU 417 TPS Sensor Signal Pin "C"
    25 TAN 472 IAT Sensor Signal Pin "B"
    26 PPL 2121 Ignition Coil 1 Control
    27 RED 2127 Ignition Coil 7 Control
    28 LT BLU/WHT 2126 Ignition Coil 6 Control
    29 DK GRN/WHT 2124 Ignition Coil 4 Control
    30 DK BLU 229 Fuel Enable Control
    31 YEL 492 MAF Sensor Signal Pin "A"
    32 LT GRN 432 MAP Sensor Signal Pin "B"
    33 DK BLU 473 High Speed Cooling Fan Relay Control
    34 DK GRN/WHT 428 EVAP Canister Purge Solenoid Control
    35 -- -- Not Used
    36 BRN 436 AIR Pump Relay Control
    37 DK GRN 83 Cruise Control Inhibit Signal
    38 -- -- Not Used
    39 RED 631 12 Volt Reference CMP Pin "C"
    40 BLK 451 Ground
    41 -- -- Not Used
    42 TAN/BLK 422 TCC Solenoid Valve Control Pin "T"
    43 DK GRN/WHT 459 A/C Clutch Relay Control
    44 LT GRN 1652 Reverse Lock Out Solenoid Control
    45 WHT 1310 EVAP Canister Vent Solenoid Control
    46 BRN/WHT 419 MIL Control
    47 YEL/BLK 1223 2 - 3 Shift Solenoid Valve Control Pin "B"
    48 LT GRN 1222 1 - 2 Shift Solenoid Valve Control Pin "A"
    49 -- -- Not Used
    50 DK GRN/WHT 817 VSS Signal
    51 YEL/BLK 1227 TFT Sensor Signal Pin "L"
    52 -- -- Not Used
    53 GRA/BLK 1687 Ignition Retard Signal EBCM only (Factory)
    54 PPL 1589 Fuel Level Sensor Signal (Factory)
    55-56 -- -- Not Used
    57 PPL 719 Low Reference IAT Pin "A"
    58-59 -- -- Not Used
    60 BRN 2129 Low Reference Ignition Coils bank 1 (1-3-5-7)
    61 BRN/WHT 2130 Low Reference Ignition Coils Bank 2 (2-4-6-8)
    62 -- -- Not Used
    63 PNK 1224 Transmission Fluid Pressure Switch Signal A Pin "N"
    64 DK GRN 890 Fuel Tank Pressure Sensor Signal (Factory)
    65 -- -- Not Used
    66 PPL/WHT 2128 Ignition Coil 8 Control
    67 RED/WHT 2122 Ignition Coil 2 Control
    68 DK GRN 2125 Ignition Coil 5 Control
    69 LT BLU 2123 Ignition Coil 3 Control
    70-75 -- -- Not Used
    76 LT GRN/WHT 1749 IAC Coil B High Control Pin "B"
    77 LT GRN/BLK 444 IAC Coil B Low Control Pin "A"
    78 LT BLU/BLK 1748 IAC Coil A Low Control Pin "C"
    79 LT BLU/WHT 1747 IAC Coil A High Control Pin "D"
    80 -- -- Not Used
    LC-1 WBO2
    Oct 2006
    Thanks for that mr.prick. Apparently with the wiring done the ls2 type knock sensors work just fine. I have the adaptor harness hooked up & I am pretty sure I have a few spare pins left over so I will be giving this a go later today. I will post up the results once tested.
    Cheers mick
    The Tremor at AIR
    Aug 2006
    VERY good question. Recently I built an engine harness to accomodate both types of sensors. I'm not sure how the customer is going to go about this, but both types were requested.
    J1 (or C1) is the BLUE connector.
    All LS controller schematics I've seen only use the 1 wire resonant type sensors.
    As far as the 1 wire knock sensor being used on LS2 and newer engines (tap side of block), I think it's simply an ignorance thing where they just don't know that the 2 wire flat response type sensors can be used with the LS1 PCM. However, I've not yet seen anyone try this. But I'm curious.
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    http://www.eficonnection.com
    Nov 2006
    What about the Knock tables?
    What .bin are you going to use for reference?
    LC-1 WBO2
    Oct 2006
    Quote Originally Posted by mr.prick View Post
    That is a good question.
    I was going to see if they can be dialled in on the standard tables. Otherwise I am sure Paul or Ross can make me up a COS in there spare time
    The Tremor at AIR
    Oct 2006
    The repin has been done to use the LS3 sensors. One thing to note is that the description in the tune tool is wrong (as shown on the info mr.prick posted as well as verified with the pin outs on my PCM) it should read
    Sensor Bank #1 - J1,pin51
    not
    The knock software needs adjusting to make it more sensitive, but exactly how much I am yet to determine. Hopefully tonight the rest of the tune is ready to get it on the dyno to do some testing. The standard ls1 KR pid still logs knock with the change in pins if anyone was wondering (like I was)
    The Tremor at AIR
    Thanks, you are correct, you know what is odd, in the description file I have here I have Pin 51 in there
Name:	Knock Sensors.png
    Oct 2006
    My mistake. I did all this on the work computer that only has a dial up connection, hence an older version (build 66, ). Obviously this has since been rectified as my tuning laptop shows the correct pin positions.
    The Tremor at AIR
    Nov 2006
    Hey Mick,
    how did this work out?
    LC-1 WBO2
  1. LS1 to LS2 cam sensor wiring help
    By Tre-Cool in forum Gen III V8 Specific
    Last Post: July 21st, 2014, 05:59 AM
  2. Knock Sensor Tuning
    By TBMSport in forum Gen III V8 Specific
    Last Post: November 24th, 2009, 08:34 PM
  3. Knock Sensor
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: November 17th, 2009, 12:24 AM
  4. New pcv - knock sensor calibration?
    By voda1 in forum Gen III V8 Specific
    Last Post: June 1st, 2007, 08:42 AM
  5. Knock sensor code
    By eboggs_jkvl in forum General
    Last Post: September 23rd, 2006, 07:15 AM
