Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Incorrect serial EQ data w/BBL
  1. #21
    Nov 2006
    I did this and it stays scan&tune. (XP Pro)
    LC-1 WBO2
  2. #22
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    This worked for me.
  3. #23
    Nov 2006
    Won't work for me.
    I select the tune.exe but it won't show in the properties.
    I can change it to the scan.exe tho.
    LC-1 WBO2
  4. #24
    Nov 2006
    Am I the only one having problems logging w/SD card?
    I have re-flashed the firmware & config files, formatted the SD car & internal memory as well as set the file system to auto.
    Internal memory is fine but it doesn't hold too many logs with the .tuns I have installed.
    LC-1 WBO2
  5. #25
    Mike, which SD card do you have (I don't remember)...?
  6. #26
    Nov 2006
    Lexar 1GB
    It worked before.
    LC-1 WBO2
  7. #27
    So, only BBL is affected, and BBR/BBW are ok... the difference between those is the length of time involved...
  8. #28
    Sep 2003
    Quote Originally Posted by mr.prick View Post
    Have you tried it with the file system set to SD instead of auto?
  1. Motec PLM Serial Data to V2
    By RetroAus in forum FlashScan V2
    Last Post: February 6th, 2016, 12:32 PM
  2. BBL & Serial LC-1
    By L31Sleeper in forum FlashScan V2 BB Logging
    Last Post: January 19th, 2010, 12:01 PM
  3. Do I need a PID to LOG serial data?
    By Chalky in forum FlashScan V2 BB Logging
    Last Post: May 15th, 2008, 11:16 PM
  4. BBL data display/record decimal places
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 27th, 2008, 03:46 PM
