Results 1 to 10 of 12
Thread: v4 cant connect
    Jul 2009
    Default v4 cant connect
    I have a VX commodore and cant connect to data log
    I keep getting checksum error and truncated error
    I have tried changing all the setting i can but no luck
    Can any one help?
    Oct 2004
    Assume it is a V6 vehicle you're connecting to? Is it a factory chip or aftermarket? I'm aware of cases where the chip is an aftermarket piece and doesn't work the same as stock (and V4 won't work).
    Andrew
    EFILive Crew
    Jul 2009
    Its a v6 stock chip the car is standard
    Oct 2004
    Are you able to post the full output with errors etc then?
    Andrew
    EFILive Crew
    Jul 2009
    I will try again next week and see if i can copy some errors
    Jul 2009
    took some data pics this is what i get
    Oct 2004
    One thing that you could try, which has helped others with your error it lowering the Chatter T6 timing from to a value of 10 (often set to around 50).
    Andrew
    EFILive Crew
    Nov 2007
    if your using a VX ecotec with a flash PCM not the L67 memcal PCM then the device ID is $F7 not $F5
    Jul 2009
    Hello i have tried changing T6 as suggested with no luck
    and i tried changing $F5 to $F7 still no luck]
    still getting the same errors
    Oct 2004
    Can you email the text (as you sow in the screenshot) to me at support@efilive.com and I'll forward on to Paul (Blacky) - he's the V4 developer and expert.
    Andrew
    EFILive Crew
  1. can not connect
    By Jetmech in forum General (Diesel)
    Last Post: November 29th, 2010, 08:31 AM
  2. LC-1 - cannot connect
    By derekf in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2010, 10:41 AM
  3. Help please trying to connect
    By 5.7senator in forum EFILive V4
    Last Post: November 21st, 2009, 10:02 AM
  4. Can't connect?
    By dbh86 in forum General (Diesel)
    Last Post: November 6th, 2008, 03:35 PM
  5. cant connect
    By mickkk in forum Duramax LLY
    Last Post: December 21st, 2006, 09:40 AM
