Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Cummins Bench Harness pinout (pictures)
    Nick, it will have to wait a week, I am over in NZ for the moment, I have all the Cummins pin-out data (pictures) back in Australia.
    Meanwhile, if anyone knows of a source for the connectors on these that would be great to know.
    For bench flashing the 5.9L ECM needs C1 & C2, for the 6.7L it only needs C2.
    Need official EFILive help, please go here.
    For tuning support please post your questions on this forum (or other auto forums).
    Sorry if I don't respond to your PM, don't take it personal.
    Mar 2007
    Those look like Deutsch pin connectors (www.laddinc.com). The 2006 one is very similar (looks like a DRC Series). Harder to tell looking at the picture of the 2009. If they are Deutsch, one source would be your local Caterpillar dealer. There are others on the web too.
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Here's what I found for the 2006 ECM:
    C1
    4 - CAN+
    5 - CAN-
    C2
    21 - Ground
    30 - Battery +12
    32 - Start/Run +12
    40 - Battery +12
    49 - Ground
    50 - Ground
    According to the data I got from OnDemand, it appears that that pinout is the same for the 2009 ECM as well.
    Personally, I think that anyone that designs an ECM that requires more than one connector to be bench flashed should be beaten....
    Quote Originally Posted by Cougar281 View Post
    Agreed, GM are guilty of this too on some of the gas ECM's.
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Anyone know where we can get the connectors and pins besides the dealer? They quoted me $149 for C1 and $169 for C2 for the 5.9L and they say they don't make any connectors for the 6.7l. Although it could be the dealer I went to.
    Jul 2006
    Does anyone know if the 2006+ can bus ECM will work as a stand a lone in my race truck. Right now I have a 03-04 ecm working but want to go with EFI. I have everything to convert it to 2006 hardware.
    ps I have access to wiring info if i can help.
    Jul 2006
    I was doing some research and it looks like on the 6.7 the Can+ is pin #1 and Can- is pin#21 on the C2 connector.
    Malcolm
    1990 CHEVY SILVERADO POWERED BY 03 CUMMINS SHIFTED BY PCS 48RE. BEST ET TO DATE 9.91@150.23 MPH
  1. Bench Harness?
    By GAMEOVER in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 31st, 2009, 11:33 AM
  2. bench harness
    Last Post: June 15th, 2006, 05:09 AM
  3. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 09:34 PM
  4. pcm bench harness
    By 69camaro5speed in forum Tutorials
    Last Post: March 26th, 2006, 12:03 PM
  5. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 03:25 AM
