Thank you
I followed the Calc VET tutorial to calculate the VE table. Used "Calculated VE, BEN corrected (g*K/kPa)" so the VE is calculated with data from the MAF ?
My next step is to disable MAF and se how the engine would run on the VE table. But due to some unexpected snow I will need to wait for the roads to dry up.
