Page 71 of 75 FirstFirst ... 21616970717273 ... LastLast
Results 701 to 710 of 741
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #701
    Yes, it will work... you need the calc_pids.txt file that has pids compatible with your controller (we currently fine tuning those calc pids).
    Are you using one or two widebands...? And which ones...?
  2. #702
    Oct 2016
    I'm using mtx-l plus, single wideband.
  3. #703
    Quote Originally Posted by BADCADDY View Post
    Are you connecting this wideband to your FSV2 using analog 0-5V or serial comms...?
  4. #704
    BADCADDY,
    please can you post your E67 tune file here, I want to look at a few things.
  5. #705
    Oct 2016
    I am using serial comms to connect to wideband, below is my current tune.
    2009 CTSV
    2.55 Pulley
    Airaid Intake
    kooks 1 7/8 headers, 3 inch X pipe
    ID 1050x injectors
    Tune is not scaled for injectors as of now.
    2009 CTSV LSA-ID1050x.ctz
  6. #706
    Ok, I have the calc_pids.txt for the E38/E67 on my PC at home, so tonite I'll post it here.
  7. #707
    Oct 2016
    Right on brother, do you want me to upload a log or two afterwards? Thanks for sharing too. I really do appreciate it.
  8. #708
    Sorry, I forgot last night my apologies... I'll send myself an email to remind me.
  9. #709
    BADCADDY,
    Here is the E67 calc_pids.txt file, rename it to calc_pids.txt, move it to folder C:\Users\<you>\Documents\EFILive\V7.5\User Configuration
    then start the scantool, select the pid CALC.WO2BEN and/or CALC.SELBEN, and then on these same pids go rightclick->More Info to see which other pids need to be selected also.
    In your tune file, table B0179 is all zeros, which I was not expecting, so in the calc_pids.txt you will see that the pid CALC.B0179 looks up zeros... when you get table B0179 populated with better values, we can update the pid CALC.B0179 with the same values.
  10. #710
    Oct 2016
    Hey Joe,
    Doing some logs tonight and will post them up, just double checking PID list looks good ?
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
