Results 1 to 6 of 6
Thread: Weird issue with Drive to Reverse and Reverse to Drive...
Hybrid View
    Default Weird issue with Drive to Reverse and Reverse to Drive...
    Anyone experience an issue where the motor will surge around 1200 RPM then drop sudenly to about 250RPM and sometimes die?!? This only happens when moving the gear selector to either reverse or drive, from either reverse or drive!! From park or neutral it gos into gear just fine. It basically surges high in between the gear grab. So when the trans has that brief moment where it kind of goes into nuetral to change to either the forward or reverse gear, it wil surge up... then drop massively once it actually catches the gear thats been selected. Also noticing that the engine will not idle at the desired idle speed while its in a gear period... about 100RPM or so under the speed. I used the Bidi controls to see if its a spark issue and i had to bring the advance to 40* in order to get the idle back up to where it used to be while in gear. Any ideas greatly appreciated...wondering if this is mechanical and not in the tune.
    Thanks,
    Nick
    01 Silverado ECSB:
    6.2L 383 Stroker IB (6.125 Rods, 4" Lunati Forged Crank, 3.903 Bore -30 cc Lunati Forged Pistons, 222/219 .550 .547 116LSA Reverse split cam, double roller timing chain, hydraulic roller lifters, TEA port n polished heads, 7.400" Pushrods, ARP Bolts everywhere), 65lbs Injectors, ASP Underdrive pulley, 160* TStat, Dynatech LT's w/ Catted Y, Gibson cat back, K&N Cold Air intake, Flex a Lite Fans, 34" radiator, EFiLive Tune
    Jul 2005
    tune your Running Airflow tables, you're probably not getting enough air at idle/near idle.
    Ok I'll check and see... I'm doing some general maintenance first before i tweak the tune just to make sure... Fuel filter (20K miles), Air Filter(Not cleaned in 10K miles), Spark plugs about 7K miles. If that doesnt fix it then Ill hop in those airflow tables. Thanks Sup
    01 Silverado ECSB:
    Thanks fellas for the responses... looks like general maintenance was what the culprit was... changed the plugs and cleaned the K&N everything is kosher
    01 Silverado ECSB:
    Cool
  1. Reverse lockout T56
    By JuhaniLS1 in forum Gen IV V8 Specific
    Last Post: December 6th, 2011, 02:42 PM
  2. Reverse lock out
    By cornetto in forum E37, E38 & E67 PFI ECM's
    Last Post: August 3rd, 2008, 02:47 PM
  3. Shift Range Inhibited when in reverse.
    By JoshH in forum FlashScan V2 BB Logging
    Last Post: June 15th, 2008, 12:26 AM
  4. Tries to die when put in reverse
    By 1SlowHoe in forum Gen III V8 Specific
    Last Post: January 5th, 2007, 04:16 PM
  5. Idles/drives great, stalls in reverse
    Last Post: August 8th, 2006, 08:58 AM
