Ok hopefully someone can tell me how to bypass something or how to fix this problem. My H2 wants to idle at about 1100 when I come to a stop which leaves me holding the brake hard. After I sit there for about 30 seconds it will eventually idle down to about 7or8oo. After frying a few pcms by trying to pull all the idle values I could think of down I was able to determine that if i start the truck, put it in neutral and crawl under it and unplug the neutral saftey switch It idled down and ran PERFECT. Problem is you cant just leave it unplugged obvioulsy because it wont start, let you take it out of park, unlock the doors when you put it in park, shift to 4 low lock ect... someone PLEASE tell me what to do!!! Thanks, Studer
ps. yes I have replaced the Neutral Saftey Switch
