Results 11 to 20 of 23
Thread: Error $050b
  1. #11
    Using EFILive Explorer you can view the file timestamps and manually copy the files, if need be.
  2. #12
    May 2008
    OK, I opened the LS1_BR.obj dated 4-1-2011 and the version is 08.02.33 and the internal date is 20110319
    I deleted the directory before downloading and installing the software so I'm not sure why it's not 08.02.35
    230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
    MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
    PowerGlide, 5000 stall converter. 8.70@154 MPH
    My Projects Homepage: http://www.horsepowerracing.com
  3. #13
    May 2008
    I found the reason why it's not working. If I download from your site it has the correct files but when I run the update program they get written over with an older version....So, your update is screwing it up!
  4. #14
    Quote Originally Posted by LS1_Dragster View Post
    Thanks for the heads up on the update thing. I'll get if fixed asap.
  5. #15
    Aug 2011
    Is there a fix for this yet? I'm having the same issue.
  6. #16
    Quote Originally Posted by electricblue View Post
    Yes it is fixed in the latest release available from our downloads page here:
    http://www.efilive.com/index.php?opt...=48&Itemid=133
    The Auto-update has been switched off so you'll need to download both V7.5 and V8 and install both V7.5 and V8 manually (i.e. by double clicking on the downloaded files).
    Make sure you use the V8 software EFILive_HAPI to update the firmware in your FlashScan.
  7. #17
    Aug 2011
    I'm still getting script error. Downloaded manually. Updated. Updated firmware.
  8. #18
    Sep 2007
    I'm having this problem as well, is there a fix yet?
  9. #19
    Did you do a manual install of the V7 and V8 .exe files...?
  10. #20
    Jan 2011
    Also having same problem.. tried deleted everything and downloaded latest files manually. Bootlock version is 2.07.04, firmware 2.07.26. Both show updated. Opened tunes in V8 and saved to convert. Needing to get this figured out for a friend. Any ideas?
    '06 2500 Cummins 4x4, Billet Trans, Airdog 150, working on tuning with EFI Live!
  1. Error $050B on V2 BBF
    By Gregs in forum FlashScan V2
    Last Post: March 19th, 2011, 03:24 PM
  2. Newbie with $050B Error
    By razorback_jd in forum AutoCal
    Last Post: February 27th, 2011, 10:00 AM
  3. error code $050B
    By hawaiianstyle in forum AutoCal
    Last Post: January 28th, 2011, 10:53 AM
  4. $050B Error message
    By jennett_c in forum FlashScan V2 BB Logging
    Last Post: July 28th, 2010, 06:37 PM
  5. Com Error
    By Neilb in forum EFILive V4
    Last Post: January 6th, 2006, 06:57 PM
