Results 1 to 5 of 5
Thread: Zeroiing E005, pilot coolant temp multiplier disables ALL pilot activity?
    Dec 2007
    Default Zeroiing E005, pilot coolant temp multiplier disables ALL pilot activity?
    I have my tune set up to disable pilot on the main table above 1800rpm and to start tapering it off on higher load at 1500rpm.
    I wanted to keep more pilot when the engine is cold up to 2200 rpm, so i adjusted my E0008 table accordingly and set my pilot coolant temp multiplier (E0005) to Zero across the 86* range.
    Now everything runs as intended, until the engine gets to 86*, then ALL pilot activity stops. I increased my main pilot quantity minimums (E0002) to 4 thinking it maybe didnt have enough duration after the additional "cold temp" pilot cut out, but that still didnt help.
    06 Laramie 3500 QC SB 4x4 - Full billet Auto by DTT, HE351/S475 twins, EFI live, lots of custom goodies....
    07 6.2L Yukon Denali - CAI, CAT delete, self tuned with EFI Live
    03 Trailblazer 4.2L I6 - CAI, custom exhaust, EFI live
    2010 Laramie 3500 CC LB 4x4 - H&S, DPF delete, waiting for EFI Live.....
    Senior Member TexasCummins's Avatar
    Jul 2011
    Yes setting any multiplier value to zero will shut it off when that parameter is met.
    EFI Live - The Smarter way to tune!
    2006 Ram 2500 4x4
    Dec 2007
    Quote Originally Posted by TexasCummins View Post
    thats unfortunate, i was hoping it only affected the values from E0008, coolant adjust, table, and would leave the E0002, quantity base, table alone.
    So then if i put say 0.5 in E0008 table across that 86* range , the 0.5 value will modify the SUM of both tables....theoretically i could modify the duration values above 1800 rpm etc etc to be too small to be recognized over 86* and still achieve my desired result....
    Dec 2007
    odd that the pilot tables calculate this way, when the post injection tables do not.
    on table E0069(post quantity coolant multiplier) i have zeroed out the post injection at the higher temperatures and it only removes the additional amounts from table E0066, not disabling ALL post activity like the pilot tables will
    Dec 2007
    after extensive testing & logging, i can not get table E0008(pilot quantity, coolant temp adjust) to add ANY fuel to the pilot amount at any operating temperature.
    E0005(coolant temp multiplier) is definately working though, & modifying table E0002 (pilot quantity base)
  1. Help with pilot timing
    By AdamRRT in forum Cummins 5.9L
    Last Post: January 6th, 2012, 10:07 AM
  2. Pilot - minimum?
    Last Post: November 7th, 2011, 04:31 AM
  3. Pilot Tuning?
    By 2006Cummins in forum Cummins 5.9L
    Last Post: October 6th, 2011, 02:10 PM
  4. Reduced power,Coolant over temp,Trans over temp
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 2nd, 2011, 10:12 AM
  5. Reduced power mode,Coolant over temp,Trans over temp
    By driver456 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 1st, 2011, 10:04 AM
