Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Error $FFFF
    Aug 2010
    Default Error $FFFF
    Any idea what this is? I tried to log some data and this kept coming up. Thanks!
    What firmware version...?
    Aug 2010
    2.06.40
    Aug 2010
    updated to 2.07.32. Should this fix my issue?
    Are both the bootblock and firmware updated...?
    After updating the firmware, did you program the BBx config...?
    Aug 2010
    Yes
    Here are two screenshots today of what I see when I try to data record
ID:	13359   Click image for larger version.
    The second pic shows it is recording.
    Aug 2010
    Really?
    Previously there was a different screen when I logged data. It had a timer of how long it was recording.
    On AutoCal immediately after starting a log, if it shows two lines:
    Line 1: Controller Type
    Line 2: PID Name
    it means that PID is not supported.
    Try deselecting the PID, reprogramming AutoCal with the new PID selection and retry logging.
    What operating system is your E38 running? The pids ending in _M are supported specific to each operating system.
    I'll check if it should be supported for you OS or not.
  1. Replies: 8
    Last Post: March 20th, 2018, 06:47 AM
  2. Error $FFFF when trying to log
    By mgmc in forum AutoCal
    Last Post: November 18th, 2010, 10:39 AM
  3. E38 Locked? $FFFF
    By SBTuner in forum E37, E38 & E67 PFI ECM's
    Last Post: December 29th, 2007, 06:22 PM
  4. Error
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2007, 09:27 AM
  5. Com Error
    By Neilb in forum EFILive V4
    Last Post: January 6th, 2006, 06:57 PM
