Results 1 to 5 of 5
Thread: IFR boost/non boost
    Mar 2007
    Default IFR boost/non boost
    We have LS1 with new 42 bosh injectors and super charger, I have changed the IFR table for the larger injectors as below, Question is now we are referencing the fuel reg to manifold pressure so we have rising rate should I still have these rising numbers or should the IFR table be flat lined?
    6.109375
    6.148438
    6.187500
    6.226563
    6.257813
    6.296875
    6.335938
    6.375000
    6.406250
    6.445313
    6.484375
    6.515625
    6.554688
    6.585938
    6.625000
    6.656250
    6.695313
    The IFR should now be flat (same value in all cells)...
    the IFR value to use is the zero vacuum value as calculated with measured rail pressure (measured with reference hose temporarily removed).
    Mar 2007
    Thats what I thought, so 58psi is the rail pressure with vac hose off so the number should be 6.110675 in all areas correct?
    Yes, correct.
    Although, since octane is 1.03 x more dense than heptane (which is used for measuring flowrate), you could also use 6.11 x 1.03 = 6.29 g/s.
    Mar 2007
    Awesome thanks
  1. Replies: 2
    Last Post: September 17th, 2008, 01:51 AM
  2. Use MAF for off boost/2 Bar SD when in boost
    By Earl H in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 24th, 2007, 11:58 AM
  3. IFR Table and Boost
    By DrX in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 22nd, 2006, 12:12 PM
