Email the trace files to me at paul@efilive.com
Copy that. BTW I install the software in other laptop, and when I connect the cable an into the car a window came up saying somthing about that the cable was for an older version software some thing like that.
Will send you the files later.
thanks Paul
Joe this is what is displayed when I try to connect
20:00:18.998: EFILive V7 Version V7.3.3 (Build 475)
20:01:51.178: Ready.
20:02:07.668: Scanning for EFILive FlashScan V1 USB
20:02:07.683: Autodetect interface ...
20:02:07.730: Connection to [FSP] interface is OK
20:02:07.730: Autodetect PCM...
20:02:07.870: Autodetect ECM...
20:02:08.011: Autodetect TCM...
20:02:08.182: Interface firmware model: FSP
20:02:08.198: Interface firmware version: 1.2.17
20:02:08.229: Interface firmware date: Jan 18, 2005
20:02:08.260: FlashScan serial number: 003597051511
20:02:08.401: Initialising PIDs...
20:02:08.510: Initialising Modules...
20:02:08.510: Ready.
20:02:26.528: Disconnecting ...
20:02:26.544: Disconnected
Is there a wey that the cable can be locked to use in only one pcm?
The trace shows that the PCM is not responding to any commands sent to it by the FlashScan V1 device.
That can because by:
1. a blown cigarette lighter fuse (does FlashScan power up when connected to the OBDII connector?)
2. faulty PCM or OBDII connector (can the scan tool software log data from the PCM?)
Not I can not log any data either. but it is kind a rare 3 different cars.
Rigth now I'm changin the pcm to my car and will test it.
Let you kow what happen
Are you saying that the V1 device will not connect to 3 different cars? If so, then that kind of indicates a problem with the V1.
Does the V1 work on any vehicles anymore?
Does the V1 power up when connected to a vehicle?
It works on my camaro, and the pcm of that other car also works, so there is a problem with the obdII port or wiring.
I will check for the other 2 98 camaros
Thanks for the help
