Results 1 to 5 of 5
Thread: 0312 Sub-scipt Code
    Aug 2012
    Default 0312 Sub-scipt Code
    I have a customer who we have EFI-live currently on and I pulled his file out again to modify and it is giving me this error code when trying to do so. Anybody have any insight as to why it is giving me this error code? Thanks!
    Reuben
    Start->All Programs->EFILive->V8->Documents->EFILive Error Codes.pdf
    $0312
    Sub Function Not Supported or Invalid Format ($12)
    The controller does not support the requested OBD mode’s sub-function.
    Contact EFILive if this error persists.
    Did you:
    - install V8 build 203...?
    - install firmware 2.07.35...?
    - program the BBx config (Program All)...?
    Aug 2012
    I have the most current software along with the firmware installed as you stated. What is programming BBx configuration?
    Jul 2012
    Are you trying to read the file you programmed to his ECM back out?
    If so do you think you could have locked the ECM when you programmed it last time? I've read from Ross you can unlock it but he didn't say how in the thread I was reading.
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Aug 2012
    Yes pulling the file back out, I don't remember locking the ECM.
  1. error 0312
    By easymon in forum Cummins 5.9L
    Last Post: August 5th, 2012, 03:23 PM
  2. Getting codes $0322, $0312 Need Help!
    By toloud4u28 in forum FlashScan V2
    Last Post: October 31st, 2010, 01:46 PM
  3. P0299 code
    By jeremybaumgardner in forum Duramax LLY
    Last Post: September 12th, 2010, 12:58 AM
  4. Code P062F and Code P0633 Help
    By Airtime in forum General (Diesel)
    Last Post: September 28th, 2009, 12:57 AM
  5. please help me, code P0606
    By miguelc in forum Gen IV V8 Specific
    Last Post: July 21st, 2009, 12:04 PM
