Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: 2013 Cadillac ATS 2.0L..
  1. #31
    Jul 2003
    Does it use factory widebands?
  2. #32
    I don't think any of GM's cars use WBO2's
  3. #33
    Jul 2003
    LNF uses wideband.... and does closed loop WOT.
    I was hoping they would come out with it with this generation... But I guess that will separate the tooners from the calibrators.
  4. #34
    Jul 2005
    Quote Originally Posted by Highlander View Post
    Whats the difference?
    peae
    Hog
    1997 rcsb stock L31 longblock, Marine Intake with 28# EV6 injectors, L35 2700 stall TC,Hooker LT's 2.007 60ft
  5. #35
    Jul 2003
    the difference is that I can spray meth with a lot less worries from the customer knowing what he or she is doing... the difference is that the changes in weather will not affect its AFR. specially on SD cars. There are so many advantages to this that is ridiculous not to have it done.
    But then again, the fact that its just easier to tune, doesn't mean that it can't be tuned. But SD cars should be "rechecked" with every season change. or at least here where humidity changes a lot. Maybe with the addition of humidity sensors things will change.... aside to that, i will not have to jack up the car to stick the wideband in front everytime one comes to tune. LOL
  6. #36
    Closed loop wideband trimming throughout the operating range (resulting measured fueling will always match commanded).
    the difference between a good tune and a bad tune will still be if the airmass model is correct (i.e. the CL WB trim will be close to zero if airmass is correct, and will otherwise deviate from zero).
  7. #37
    Jul 2003
    You can still achieve this and airmass model NOT be correct... due to bad injector data and similar situations.
  8. #38
    Yeah, but you are talking a Bosch ECM here right?
  9. #39
    Jul 2005
    I apologize, but I was wondering what the difference between a tuner and a calibrator was? Sorry.
    peace
    Hog
  10. #40
    Jan 2011
    Ran a 12.9 sec 1/4 mile at 107.6 mph with the ATS4 2.0T automatic today after installing a turbo back exhaust (3" catless dp feeding into dual 2.5" exhaust), 64 mm compressor wheel upgrade and HL turbine wheel upgrade. Ran this one on 93 octane + meth/water but will switch over to E85 +meth/water after some fine tuning on the dyno next week. No problems raising the bar to over 400hp on the 2.0T E39A with EFILive!
Name:	ATS Qrt Mile VTS2 93 MethWater.jpg
    Brian
  1. When the EFI live support for 2013 Yukon 5.3, 6.0 L?
    By hthy in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2012, 05:23 AM
  2. ATS turbo on LBZ with DTCs?
    By JoakimMD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 28th, 2009, 02:12 AM
  3. Cadillac vats ?
    By RPO_Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2009, 03:41 PM
  4. Cadillac XLR-V
    By Spindoctor in forum E37, E38 & E67 PFI ECM's
    Last Post: June 1st, 2008, 10:58 AM
