Results 1 to 5 of 5
Thread: Update: June 05, 2013
    Default Update: June 05, 2013
    EFILive encourages customers to use this public update in their production environments.
    Important:
    This latest software update requires updated USB drivers (V2.08.28). You cannot use this version of the software with older versions of the USB drivers.
    If you are having difficulty connecting to FlashScan/AutoCal after installing this update, DO NOT DOWNGRADE THE USB DRIVERS.
    Even More Important:
    The boot block software for FlashScan and AutoCal has been updated to increase the stability of flash memory erase and flash operations under varying environmental conditions. You should update the boot block in your FlashScan and/or AutoCal devices when prompted to by the EFILive Control Panel. If you are not prompted to update the boot block, please manually run the EFILive Control Panel software, select the [F6: Firmware] tab page and update the boot block. After updating the boot block the device will remain in dead-poll until you reprogram the latest firmware into it.
    Download here:
    Updates:
    V7
    • When attempting to flash a controller using a Scan Only device, a message explaining that Scan Only devices cannot be used for flashing is now displayed.
    • PID name conversion corrected from TCMPSLIP->TCSLIP to TCMPSLIP->TCMSLIP
    • Renamed all E40 DMA PIDs from GM.xxxx_DMA PIDs to E40.xxxx_DMA
    V8
    • Pasting PIDs when no controller selected in BBX caused Access Violation.
    • When copying/pasting PIDs in BBX and SCAN windows, alarms and custom units are now only be copied when pasting BBX PIDs, not when pasting SCAN PIDs.
    • Fixed error caused when an invalid format is entered by the user for chart axis labels and values.
    Boot Block
    • Updated flash routines to make flash operations more stable under varying conditions.
    Firmware
    • Updated firmware to be compatible with boot block V2.07.05.
    • Fixed record all DTCs to include FF data.
    • Fixed FF display to remove spurious up/down arrow characters.
    Known Issues:
    Please post issues, questions, clarifications (large or small) in this thread.
    As issues are reported and confirmed they will be re-posted as "Known Issues" below.
    • Reading LBZ/LML controllers may result in "Merge" error (fixed in next update).
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 234
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 228
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.05 (May 31, 2013
    To view the installed version, Select F7: Licenses (in the V8 Scan and Tune software).
    Firmware: V2.07.44 (
    May 31, 2013)
    Mar 2012
    Updated and got this today.
    Quote Originally Posted by SkinnyPedal View Post
    It was a known issue in the previous version, thought it was fixed in this version.
    Working on this right now, should have a solution available in the next hour or two.
    Mar 2012
    Thanks!!
  1. Update: May 25, 2013
    Last Post: June 11th, 2013, 05:28 PM
  2. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  3. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
  4. Public Release Update June 24, 2011
    Last Post: July 9th, 2011, 06:21 AM
  5. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 11:09 AM
