What does it mean when you have a weak cylinder in the cylinder balance test,And how do you correct it?.....................Paul
It means that cylinder is not running as strongly as the others.
How to correct it?
That usually requires some mechanical knowledge and equipment.
Causes could be
spark plug
ht lead
coil
injector
riding valve
burnt valve
holed piston
bad inj driver
Bad contact or broken wire to coil or injector
broken valve spring
seized valve
Starting to get the idea?
\"You Can Never Have Enough Horsepower\"
Can you post a screen picture of the test results...
.. piston rings, damaged bore, blown head gasket etc..
If its shocking you can fix it with a 402 stroker engine replacement
2014 VF SV LS3 Maloo.
Its on my lap top and thats not connected to the internet.Oh man I hope its just a bad plug.I went to the Corvette Challenge in NJ on Saturday and went a 12.44,The car feels and sounds great and I'm about half done tuning it,Idles a little ruff though.UPDATE,I changed the #4 cyl.plug and its a little stronger now.Originally Posted by joecar
FWIW - I did back to back cylinder tests and got very different results. 1 st test showed 2 weak cylinders and the second showed the previously weak cylinders stronger than the stongest cylinder from the 1 st test. It was much more consistant after the second test. Also nothing changed between tests and were done within about 2 min. of each other. I chalked it up to a fluke.
Arctic White 2001 WS6 M6
Kooks SS LT's w/ catted Y, Borla, White face gauge inlays, Qwik Stick, EFI Live, PLX WB,
KVT 915, JL 500/5, 10W3, JL XR 6.5" front separates/MB Quart 5.25 rear separates
316 hp/329 tq w/ Borla only
12.89 @ 111.55 w/ 2.102 60'
8 rib D1SC 8#, SC1 cam, Patriot duels, Comp pushrods, Ti retainers, Motron 60# injectors, Racetronics pump kit, Fuel Rails
541 hp/457 tq w/ Blower and Cam
Yea,cause now its showing #8 cyl. week,Oh well.As long as its not a valve or piston damage I'm gladOriginally Posted by DWS6
