Results 1 to 10 of 13
Thread: 4L60E wont lockup using bidirectional controls
    Apr 2014
    Default 4L60E wont lockup using bidirectional controls
    Hey all!
    A little background on the setup:
    Built Sonnax 4L60e
    Precision Triple disk converter
    Efilive V1
    Ive got a problem. I cant seem to get my built 4l60e to lock the converter using the bidirectional controls. I can drive it and hit the "TCC Enable Solenoid" button and set the "TCC control solenoid" to 100% and it will lockup.....but it doesnt stay locked. However, Ill lock it in 3rd using the bidirectional controls and it wont downshift which is what its supposed to do, but then I make a pull in 3rd and the car will show about 800-900rpm converter slip speed and the TCC mode stays on "OFF".
    It seems like the controls only work sometimes. Is there a problem with my car/cable/efilive? Is there anyway I can FORCE it to hold 3rd gear and lock the converter so I can get a clean pull for tuning?
    Thanks in advance,
    Anthony
    Heres a log:
    Log_0021.efi
    Heres my map:
    DTM FINAL NEW PULSE WIDTH VOLTAGE.tun
    Nov 2007
    I have the same issue. Nothing I do works. I wasted an hour of dyno time yesterday trying to get this stupid thing to lock up. I am using the V2 in an 07' TBSS. I just wrote another tune last night to not allow it to shift into 4th or down shift into 2nd. What is the deal?
    02 Z06, 573/530rw N/A 416, 10.21@136.12.
    Log the TSTATEnn pids, some of those contain bit flags indicating the reason for TCC unlock.
    BTW, also, fix these:
    Out of Range calibration summary: 01:10:13 pm, Tuesday Jun 17, 2014
    EFILive Custom Calibrations
    {A0000} Forced Octane Scaler, was out of range when loaded.
    {A0001} Forced Octane Scaler Percentage, was out of range when loaded.
    {A0002} Octane Scaler Limiter, was out of range when loaded.
    {A0011} PCM Input #1 Function, was out of range when loaded.
    {A0012}
    {A0013}
    Engine Calibration.Fuel.DFCO
    {B3308} DFCO M6 Enable Temp, was out of range when loaded.
    Engine Calibration.Fuel.Mixture
    {B3614} Hot PE Mode Coolant Temp Threshold, was out of range when loaded.
    Engine Calibration.Fuel.Lean Cruise
    {B3636} Vehicle Speed Lean Cruise Enable, was out of range when loaded.
    Engine Calibration.Fuel.Trim
    {B3803} Maximum Coolant Temp to Enable LTFT, was out of range when loaded.
    Engine Calibration.Abuse Management
    {B1207} Abuse Management Vehicle Speed Threshold, was out of range when loaded.
    System.Theft
    {G1201} Anti Theft Configuration, was out of range when loaded.
    System.Fans
    {G0903} Fan #1 Turn-on By A/C Temp, was out of range when loaded.
    Senior Member MyM8V8's Avatar
    Aug 2008
    I also had that problem with a 4L65E / T42. Could not get the convertor to stay locked on the dyno. Wasted a trip to the dyno. I have asked about this problem before but I don't think we got anywhere with it??
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    Nov 2007
    I just wrote another dyno only trans tune. I set it up to no allow the shift to 4th and not let it kick down to 2nd. I will have to lock the converter that way also. Mine wouldn't even hold the gear. I am not even really worried about the converter right now. A guy I know with HPT told me that you have to set up the CGCL's in the diagnostic portion of the trans tune to allow the DVT to work. I am not seeing what he is talking about. Just a bunch of fault actions.
    Cgcl = ?
    Nov 2007
    Cgcl = ?
    That's what I said. I have no idea what cgcl is. One question I do have is for the kick down to 2nd, do I lower it to 20mph or so or do I set it at 140mph or so? For some reason it is messing with my head if preventing the kickdown is done by raising or lowering the mph.
    Aug 2008
    I had those fault messages come up on the dyno through the DVT panel too, and I don't think it matters what you tell it to do in the tune either. Something from the TCM is telling it to unlock the convertor clutch and I suspect its something to do with high torque loads its seeing (or assuming). A solution on here would be great?
    Nov 2007
    Like I said above. I would be glad if I could just get it to hold a gear. The torque converter lock up would be a bonus.
  1. Replies: 8
    Last Post: May 16th, 2007, 10:04 AM
  2. Pull timing with bidirectional controls to test for KR?
    By Xtnct00WS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 27th, 2006, 04:11 PM
  3. Bidirectional controls and spark....
    By Redline Motorsports in forum General
    Last Post: June 12th, 2006, 02:35 PM
  4. Bidirectional Controls and V7
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2005, 04:53 PM
