Results 1 to 5 of 5
Thread: Lml map
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    Default Lml map
    was playing around with a LML today and I'm not sure if the headers on this map is correct. I'm using 7.5 build 265.Click image for larger version.
    EFILive Beta Tester
    2006 DODGE RAM 2500 4X4 Industrial Injection R1 100HP Injectors and BAG-O-PARTS, ATS Exhaust Manifold, AFE 67MM Turbo and MANIFOLD
    Yeah it looks like the labels are on the wrong axis, I'll fix it now, thanks.
    Fixed for next update....
    Jun 2013
    Did you see that B0555 is the same way? thanks
    EFILive Beta Tester
    yes I did thanks.
  1. LML Support
    By 30 RUM in forum Duramax 2011+ LML / LGH
    Last Post: October 25th, 2015, 12:26 PM
  2. LML will not open
    By panzerwillie in forum Duramax 2011+ LML / LGH
    Last Post: September 4th, 2014, 02:05 PM
  3. Changing from a 2bar map to a 3bar map?
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 23rd, 2006, 04:31 PM
