Results 1 to 2 of 2
Thread: VZ or VE Maf Sensor
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default VZ or VE Maf Sensor
    Looking at the two maf sensors they are almost physically the same size apart from length. Is there really any great advantage in airflow between the two? Does the VE maf maybe record a lower Hz for the same airflow?
    Pics attached.
ID:	17756   Click image for larger version.
ID:	17757   Click image for larger version.
    Aug 2006
    The longer of the two MAF sensors appears to be bigger---At least on the outside. That means the inside "should" be bigger and flow more air. How much more air, I don't know. I would say your MAF tables would definitely need to be touched up after that install.
    Jeff
  1. MAF Sensor Calibration '98 Trans Am
    By 12_Square in forum Gen III V8 Specific
    Last Post: January 6th, 2014, 08:37 PM
  2. Tuning Around a MAF Sensor
    By WisconsinHick1 in forum Duramax LLY
    Last Post: May 6th, 2013, 02:50 PM
  3. 5 wire maf/iat sensor
    By vcls1 in forum Gen IV V8 Specific
    Last Post: May 7th, 2012, 01:27 PM
  4. IAT Sensor when MAF bypassed
    By Robbie The Wrench in forum Gen III V8 Specific
    Last Post: August 16th, 2008, 08:33 AM
  5. AutoVE MAF sensor calibration
    By Ritch in forum Gen III V8 Specific
    Last Post: June 21st, 2007, 10:33 AM
