Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: Can't read or flash ECM
  1. #21
    Jun 2010
    I also had this problem. I first had the $0322 code. I applied the patch and now it attempts even less and reads "Script file not supported by current software version".
  2. #22
    Quote Originally Posted by Bohmer View Post
    Run the V8 software and click on the [Check Firmware] button. Then click on the [Update Files] option.
  3. #23
    Jun 2010
    There is no "update files" option. Says boot, firmware,and configure files are ok
  4. #24
    What are the boot block and firmware versions and dates?
    Can you post a screen shot of the [Check Firmware] screen?
  5. #25
    Jun 2010
    Boot block: 2.07.07 feb 7 2014
    Firmware: 2.07.76 jan 27 2014Click image for larger version.
  6. #26
    I highly recommend downloading and installing this version: https://forum.efilive.com/showthread...te-Feb-14-2015
    After installing the V8 software, click on the [Check Firmware] button, you should be prompted to update the firmware to V2.07.79.
  7. #27
    Senior Member djv86's Avatar
    Nov 2014
    When I installed the patch it works great now for me
  8. #28
    Jun 2010
    Installed the update and reinstalled patches and it worked. Is there any way to tell if stock files are corrupt like the CMC controllers?
  9. #29
    May 2010
    I tried to read a tune from a 2006 cummins this morning and it failed to read the tune. I was using v8 build 269 to read it. I got on here and see these patches to correct failed reads on cmb 849 controllers. If I update to latest release will these patches still be needed?
  10. #30
    Quote Originally Posted by superwagon View Post
    If you update to this version here:
    https://forum.efilive.com/showthread...se-Candidate-1
    then you won't need to apply any other patches, everything is included.
    You must install both V7.5 and V8.
    Don't forget to update your FlashScan/AutoCal firmware using the V8 software's [Check Firmware] button.
  1. Replies: 18
    Last Post: February 20th, 2015, 07:01 AM
  2. cannot read or scan ECM after BBF flash
    By THEFERMANATOR in forum Duramax LB7
    Last Post: March 27th, 2011, 03:36 PM
  3. I can't read a tune, but can flash one
    By dlove in forum FlashScan V2
    Last Post: October 2nd, 2009, 11:19 PM
  4. can read but cant flash ecm
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: November 25th, 2008, 12:37 PM
  5. Cant read the ECM?
    By sweetdiesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 25th, 2008, 10:19 AM
