Results 1 to 1 of 1
Thread: March 2015, EFILive Release Candidate 1
    Default March 2015, EFILive Release Candidate 1
    Please download and install both the V7.5 and V8 software packages.
    Both the V7.5 and V8 software was updated in this release, you must update both software packages.
    Release Candidate 1 is no longer available. Please go here to download the latest Release Candidate 2 software:
    https://forum.efilive.com/showthread...se-Candidate-2
    Release Notes:
    Known Issues:
    Check for known issues here.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 280
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 274
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.81 (Mar 18, 2015
    To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
  1. Known issues with March 2015, Release Candidate 1
    Last Post: April 10th, 2015, 10:03 AM
  2. Release Candidate 1, Aug 04, 2011
    Last Post: September 11th, 2011, 03:36 AM
  3. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
