Results 11 to 20 of 21
Thread: Windows 10 compatibility
  1. #11
    Apr 2005
    FWIW we have a Surface 3 here running EFILive on Windows 10 with no problems at all.
    I have 3 machines here, used to work fine before updating from windows 7. Prior to the last EFILive update...the V8 software would just lock up, now I get the access violation...literally 98 times out of 100. Basically making it unusable. All 3 act the same way...different brand laptops and different processors.
  2. #12
    Jan 2006
    Are there any official words from company?
    Custom Tuning Services
  3. #13
    Quote Originally Posted by killerbee View Post
    EFILive is supported on Windows 10.
    Have you tried uninstalling/reinstalling the USB drivers?
    To do that, use the EFILive V8 USB Manager program:
    1. Disconnect all EFILive devices.
    2. Click the [Uninstall USB Drivers] button. Wait for them to be uninstalled.
    3. Then click the [Install USB V2.08.28] drivers. Wait for them to be installed.
    4. Connect one EFILive device and wait for the driver installation to complete - it may take a while if Windows decied to go esearch the Windows Driver Database online. You can cancel that if you wish, EFILive's USB drivers are not available in the Windows Driver Database.
    You may also need to switch off "USB xHCI" in your PC BIOS.
  4. #14
    Apr 2005
    Here is what I have tried. Installing the latest software on two different machines (as well as updating the one I was using). I am getting a access violation when I try to open a calibration to get ready to flash.
  5. #15
    Jan 2006
    I uninstalled and cleaned up both versions (left from windows 7) and reinstalled both 7.5 and 8 on top of Windows 10. My problem resolved, communication established.
    fyi
  6. #16
    Quote Originally Posted by Jason S. View Post
    When you say latest software do you mean the public release software from our web site, or the pre-release from our forum?
    I highly recommend using the pre-release from here: https://forum.efilive.com/showthread...ic-Pre-Release
    If you are using that version and that version gives an access violation:
    1. When exactly does the error happen? When you open the *.ctz file? When you click the [Cal Flash] button?
    2. Does it happen with any *.ctz file or just that particular file? (If its just that particular file, can you please send me that file).
    3. Does it happen when you attempt to load a file for a different controller type? Or attempt to flash a different controller type?
    One other thing to try is this:
    Uninstall the V8 software, then delete the entire V8 installation folder and everything inside it: \Program Files (x86)\EFILive\V8.
    You may need adminstrator priviliges to delete the folder and its contents.
    Then re-install the V8 software.
  7. #17
    Jan 2006
    I used today's PUBLIC pre-release in the download section, I think it was Aug 13. good outcome.
  8. #18
    Apr 2005
    It's the Release off of the site, not the forum.
    I get the error when I try to open the cal file in preperation for flashing.
    I am only working with the E92 controller at the moment
  9. #19
    Sep 2015
    Quote Originally Posted by garrettg.bpd View Post
    I upgraded to windows 10. I modified and saved a tune file after upgrading. now when I try to open it I get this.Attachment 18706
    I am having the same problem running under Windows 10. Every file I modified causes that message when I try to open it under V8. Each of those files can be opened under V7.5.
    Please share your solution.
  10. #20
    Quote Originally Posted by gaduser View Post
    I am having the same problem. Every file I modified causes that message when I try to open it under V8. Each of those files can be opened under V7.5.
    Make sure both your V7.5 and V8 software is up to date. Download and install the latest pre-release from here:
    After installing V8, run it and click on the [Check Firmware] button to ensure the firmware and config files on FlashScan/AutoCal are up to date.
    When you check the Help->About in the V7 tune software it should show build 293
    When you check the [About] button in the V8 scan&tune software it should show build 286
  1. E40 OS Compatibility
    By SkinnyPedal in forum Gen III V8 Specific
    Last Post: April 15th, 2014, 04:33 AM
  2. OS Compatibility Question
    By Webbs in forum E37, E38 & E67 PFI ECM's
    Last Post: September 13th, 2013, 02:22 AM
  3. Windows 8 Compatibility
    By robertleeii in forum General
    Last Post: June 18th, 2012, 03:17 PM
  4. Compatibility
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 18th, 2008, 12:53 PM
  5. Viper Compatibility?
    By Donovan in forum Petrol / Gas
    Last Post: August 26th, 2008, 09:21 PM
