Results 11 to 20 of 26
Thread: Known issues with Aug 13, 2015 Public Pre-Release
    Quote Originally Posted by jrh View Post
    Anyone else getting an EFILive Explorer error $0030 (The application and EFILive_Hapi versions are not compatible) after updating to the August 13th release?
    My Mistake, I've rebuilt the install with the correct version of EFILive_Explorer.
    Please re-download and re-install V8 from here: http://download.efilive.com/Software...ate1_Setup.exe
    That appears to have fixed it. I can now connect to the V2 devices using EFILive Explorer. Thanks.
    Jason Haines, Project Director
    Lingenfelter Performance Engineering
    http://www.lingenfelter.com
    jhaines@lingenfelter.com
    260-724-2552
    Aug 2015
    E67 link file incorrectly linking to e38 pids in *octane maps.
    Quote Originally Posted by b4pjs View Post
    +1
    And also these are backwards:
    Code:
    ;IAT vs RPM Spark Multiplier
    B5108.ROW=SAE.IAT
    B5108.COL=SAE.RPM
    I'll be honest, EFILive is not currently maintaining those link files but they are open text files so anybody can change them and some of the ones in the software are user modified versions.
    Aug 2015
    I did send in a fixed version to the support email. Needs joecars mods done to it though.
    There does seem to be a lot of references to E38 pids as well. Should these all be set to E67?
    Aug 2015
    My current link file with joecar's correction. Should the VVE tables really be linking to E38 pids?
    Code:
    ;  _______________________________________________________________________
    ; |                        © 1998, EFILive Limited                        |
    ; |                      web: http://www.efilive.com                      |
    ; |                        email: info@efilive.com                        |
    ; |_______________________________________________________________________|
    ; Date         Who Why
    ; ____________ ___ _________________________________________________________
    ; 2013-Jun-21   PB Split single, large "cal_link.txt" file into multiple,
    ;                  smaller controller specific "CCC_Link.ini" files
    ;                  where CCC is the controller's code.
    ; __________________________________________________________________________
    ; E67 (GenIV 2006/2007)
    ; ROW runs Vertical - Y Axis
    ; COL runs Horizontal - X Axis
    [E67]
    ; Virtual VE tables
    B8101.ROW=SAE.RPM
    B8101.COL=SAE.MAP
    B8101.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8102.ROW=SAE.RPM
    B8102.COL=SAE.MAP
    B8102.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8103.ROW=SAE.RPM
    B8103.COL=SAE.MAP
    B8103.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8104.ROW=SAE.RPM
    B8104.COL=SAE.MAP
    B8104.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8105.ROW=SAE.RPM
    B8105.COL=SAE.MAP
    B8105.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8106.ROW=SAE.RPM
    B8106.COL=SAE.MAP
    B8106.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8151.ROW=SAE.RPM
    B8151.COL=SAE.MAP
    B8151.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8152.ROW=SAE.RPM
    B8152.COL=SAE.MAP
    B8152.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8153.ROW=SAE.RPM
    B8153.COL=SAE.MAP
    B8153.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8154.ROW=SAE.RPM
    B8154.COL=SAE.MAP
    B8154.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8155.ROW=SAE.RPM
    B8155.COL=SAE.MAP
    B8155.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    B8156.ROW=SAE.RPM
    B8156.COL=SAE.MAP
    B8156.RRR=CALC.BEN1_E38,CALC.BEN2_E38,CALC.BEN_AUT1_E38,CALC.BEN_AUT2_E38,CALC.BEN_FJO1_E38,CALC.BEN_FJO2_E38,CALC.BEN_LC11_E38,CALC.BENLC12_E38,CALC.BEN_LM11_E38,CALC.BEN_LM12_E38,CALC.BEN_PLX1_E38,CALC.BEN_PLX2_E38,CALC.BEN_TE1_E38,CALC.BEN_TE2_E38,CALC.BEN_WBC1_E38,CALC.BEN_WBC2_E38
    ;Stoichiometric AFR
    B3671.ROW=GM.E85PCT
    ;Cranking Commanded Fuel
    B0138.ROW=SAE.RUNTM
    B0138.COL=SAE.ECT
    ;Cranking Ethanol Coolant Adjust
    B0139.ROW=SAE.ECT
    ;Cranking Ethanol Blend Factor
    B0140.ROW=GM.E85PCT
    ;P.E. Mode Throttle Threshold
    B0156.ROW=SAE.RPM
    ;P.E. Mode Throttle Treshold IAT Modifier
    B0158.ROW=SAE.MAP
    ;P.E. Mode Timer Counter
    B0168.ROW=SAE.TP
    B0168.COL=SAE.RPM
    ;P.E. Mode Commanded Fuel
    B3618.ROW=SAE.RPM
    ;Engine Runtime for Closed Loop
    B1501.ROW=SAE.ECT
    ;Engine Coolant Temp for Closed Loop
    B1502.ROW=SAE.ECT
    ;Engine Runtime for O2 Ready
    B1503.ROW=SAE.ECT
    ;Engine Coolant Temp for O2 Ready
    B1504.ROW=SAE.ECT
    ;Long Term Trim MAP Disable
    B1510.ROW=SAE.BARO
    ;Open Loop Normal Commanded Fuel in Gear
    B0141.ROW=SAE.ECT
    B0141.COL=E38.INVLVTMP_DMA
    ;Open Loop Ethanol Commanded Fuel in Gear
    B0142.ROW=SAE.ECT
    B0142.COL=E38.INVLVTMP_DMA
    ;Open Loop Normal Commanded Fuel in P/N
    B0143.ROW=SAE.ECT
    B0143.COL=E38.INVLVTMP_DMA
    ;Open Loop Ethanol Commanded Fuel in P/N
    B0144.ROW=SAE.ECT
    B0144.COL=E38.INVLVTMP_DMA
    ;Open Loop Ethanon Blend Factor
    B0145.ROW=GM.E85PCT
    ;Open Loop Fuel IVT Multiplier
    B0146.ROW=E38.INVLVTMP_DMA
    B0146.COL=SAE.MAP
    ;Open Loop Fuel Load Multiplier
    B0148.ROW=SAE.MAP
    B0148.COL=SAE.RPM
    ;Injector Flow Base
    B1215.ROW=E38.INJPDELTA_DMA
    ;Injector Flow Correction (Vac/Delta)
    B1210.ROW=E38.INJPDELTA_DMA
    B1210.COL=GM.VOLTS
    ;Injector Flow Correction MAP
    B1211.ROW=SAE.MAP
    B1211.COL=GM.VOLTS
    ;Injector Flow Modifier IAT
    B1213.ROW=SAE.IAT
    ;Injector Flow Modifier Voltage
    B1214.ROW=GM.VOLTS
    ;Minimum Injector Pulse Width
    B1203.ROW=SAE.RPM
    ;Injection Timing ECT
    B1205.ROW=SAE.ECT
    ;Injection Timing RPM
    B1206.ROW=SAE.RPM
    ;Injection Timing Extra Pulse ECT
    B1207.ROW=SAE.ECT
    ;Injection Timing Extra Pulse RPM
    B1208.ROW=SAE.RPM
    ;Airflow Correction Coolant Multiplier
    B1602.ROW=SAE.ECT
    ;Desired Idle Speeds
    B1821.ROW=SAE.ECT
    ;Idle Overspeed Correction Multiplier
    B1823.ROW=SAE.ECT
    ;Idle Underspeed Correction Multiplier
    B1824.ROW=SAE.ECT
    ;Airflow Correction Baro Multiplier
    B1601.ROW=SAE.BARO
    ;A/C Torque Compensation 1
    B1825.ROW=SAE.MAF,GM.MAF,GM.DYNAIR
    ;A/C Torque Compensation 2
    B1826.ROW=SAE.MAF,GM.MAF,GM.DYNAIR
    ;Minimum Idle Airflow
    B1829.ROW=SAE.RPM
    B1829.COL=GM.GEAR
    ;Cranking Idle Air
    B1832.ROW=GM.RUN_TIME
    B1832.COL=SAE.ECT
    ;High octane Spark Table
    B5101.ROW=SAE.RPM
    B5101.COL=E67.APCYL_DMA
    ;Low octane Spark Table
    B5102.ROW=SAE.RPM
    B5102.COL=E67.APCYL_DMA
    ;High octane AFM Spark Table
    B5103.ROW=SAE.RPM
    B5103.COL=E67.APCYL_DMA
    ;Low octane AFM Spark Table
    B5146.ROW=SAE.RPM
    B5146.COL=E67.APCYL_DMA
    ;Coolant Temp Spark Table
    B5105.ROW=SAE.ECT
    B5105.COL=E67.APCYL_DMA
    ;Coolant Temp Spark Multiplier
    B5106.ROW=SAE.RPM
    B5106.COL=SAE.ECT
    ;IAT Spark Table
    B5107.ROW=SAE.IAT
    B5107.COL=E67.APCYL_DMA
    ;IAT Spark Table 2
    B5147.ROW=SAE.IAT
    B5147.COL=E67.APCYL_DMA
    B5108.ROW=SAE.RPM
    B5108.COL=SAE.IAT
    ;IAT vs ECT Spark Multiplier
    B5109.ROW=SAE.ECT
    ;EGR Spark Table
    B5110.ROW=SAE.RPM
    B5110.COL=E67.APCYL_DMA
    ;EGR AFM Spark Table
    B5111.ROW=SAE.RPM
    B5111.COL=E67.APCYL_DMA
    ;Fuel Mixture Spark Correction
    B5112.ROW=SAE.RPM
    B5112.COL=GM.EQIVRATIO
    ;Fuel Mixture Spark Multiplier
    B5113.ROW=SAE.MAP
    ;Flex Fuel (Ethanol) Spark
    B5114.ROW=SAE.RPM
    B5114.COL=E67.APCYL_DMA
    ;Flex Fuel (Ethanol) Mixture Spark Correction
    B5115.ROW=SAE.RPM
    B5115.COL=GM.EQIVRATIO
    ;Cold Engine Noise Reduction Table
    B5116.ROW=SAE.RPM
    B5116.COL=E67.APCYL_DMA
    ;Cold Engine Noise Reduction Multiplier
    B5117.ROW=SAE.ECT
    ;Torque Reduction Min Timing
    B5153.ROW=SAE.RPM
    ;Piston Protection Mode Timing Limit
    B5118.ROW=SAE.RPM
    ;Cranking Spark
    B5119.ROW=SAE.RPM
    B5119.COL=SAE.ECT
    ;Spark Dwell Time
    B5120.ROw=SAE.RPM
    B5120.COL=GM.VOLTS
    ;Spark Dwell Time Multiplier
    B5121.ROW=E38.COILTEMP_DMA
    B5121.COL=GM.VOLTS
    ;Coast Down Spark High RPM Correction
    B5123.SAE.RPM
    ;Coast Down Spark High LOW Correction
    B5124.SAE.RPM
    ;Base Idle Spark Table
    B5104.ROW=SAE.RPM
    B5104.COL=E67.APCYL_DMA
    ;Coast Down Spark
    B5122.ROW=SAE.RPM
    B5122.COL=E67.APCYL_DMA
    ;Idle Spark ECT Correction (In Gear)
    B5125.ROW=SAE.ECT
    ;Idle Spark ECT Correction (In P/N)
    B5126.ROW=SAE.ECT
    ;Idle Baro Correction
    B5127.ROW=SAE.BARO
    ;Idle High RPM SPark Correction (In Gear)
    B5128.ROW=SAE.RPM
    ;Idle Low RPM SPark Correction (In Gear)
    B5129.ROW=SAE.RPM
    ;Idle High RPM SPark Correction (In P/N)
    B5130.ROW=SAE.RPM
    ;Idle Low RPM SPark Correction (In P/N)
    B5131.ROW=SAE.RPM
    ;Idle Low Spark Lower Limit
    B5132.ROW=SAE.ECT
    ;Startup RPM Flare Control
    B5133.ROW=SAE.RPM
    ;Startup RPM Flare Control Multiplier
    B5134.ROW=SAE.ECT
    ;Crank to Idle Spark Blend
    B5135.ROW=SAE.ECT
    ;Knock Fast Attack Rate
    B1902.ROW=SAE.RPM
    ;Knock Fast Attack Coolant Multiplier
    B1903.ROW=SAE.ECT
    ;Knock Fast Attack Baro Multiplier
    B1904.ROW=SAE.MAP
    ;Knock Fast Attack Retard Limit
    B1905.ROW=SAE.RPM
    B1905.COL=SAE.MAP
    ;Knock Recovery Rate
    B1906.ROW=SAE.RPM
    B1006.COL=
    ;Burst Knock IAT Multiplier
    B1918.ROW=SAE.IAT
    ;;Burst Knock RPM Multiplier
    B1919.ROW=SAE.RPM
    ;Burst Knock ECT Multiplier
    B1920.ROW=SAE.ECT
    ;Octane Scalar Startup Gain
    B1927.ROW=SAE.ECT
    B1927.COL=SAE.IAT
    ;Octane Scalar Increment
    B1928.ROW=GM.KR
    ;Knock Balancing Rates
    B1940.ROW=SAE.RPM
    ;Launch Spark Airflow
    B1948.ROW=SAE.RPM
    ;Launch Spark Airflow Multiplier
    B1949.ROW=SAE.ECT
    ;Launch Spark
    B1950.ROW=SAE.ECT
    B1950.COL=GM.RUN_TIME
    ;Launch Spark Hold
    B1951.ROW=SAE.ECT
    ;Launch Spark RPM Multiplier
    B1954.ROW=SAE.RPM
    ;Launch Spark Heat soak Multiplier
    B1957.ROW=GM.RUN_TiME
    ;Launch Spark Throttle Multiplier
    B1957.ROW=SAE.TP
    ;Launch Spark Decay Rate
    B1957.ROW=SAE.ECT
    ;Knock Threshold Cylinder A
    B1967.ROW=SAE.RPM
    B1967.COL=
    ;Knock Threshold Cylinder B
    B1968.ROW=SAE.RPM
    B1968.COL=
    ;Knock Threshold Cylinder C
    B1969.ROW=SAE.RPM
    B1969.COL=
    ;Knock Threshold Cylinder D
    B1970.ROW=SAE.RPM
    B1970.COL=
    ;Knock Threshold Cylinder E
    B1971.ROW=SAE.RPM
    B1971.COL=
    ;Knock Threshold Cylinder F
    B1972.ROW=SAE.RPM
    B1972.COL=
    ;Knock Threshold Cylinder G
    B1973.ROW=SAE.RPM
    B1973.COL=
    ;Knock Threshold Cylinder H
    B1974.ROW=SAE.RPM
    B1974.COL=
    ;Knock Threshold Transient Mods
    B1975.ROW=SAE.RPM
    ;Knock Threshold EQRatio Multiplier
    B1976.ROW=GM.EQIVRATIO
    ;DFCO Spark Transition Delay
    B5148.ROW=SAE.TP
    ;DFCO Enter Spark Timing
    B5149.ROW=SAE.RPM
    ;DFCO Exit Spark Timing
    B5150.ROW=SAE.RPM
    ;CFCO Spark Transition Delay
    B5151.ROW=SAE.TP
    ;CFCO Enter Spark Timing
    B5152.ROW=SAE.RPM
    B5152.COL=E67.APCYL_DMA
    ;TcS Throttle Limiter by Gear
    B2514.ROW=SAE.RPM
    B2514.coL=GM.GEAR
    ;TCS Throttle Limiter by Gear, IAT Multiplier
    B2515.ROW=SAE.IAT
    B2515.COL=GM.GEAR
    ;TCS Throttle Limiter by Input Speed
    B2517.ROW=SAE.RPM
    B2517.COL=GM.GEAR
    ;Torque Reduction Max
    B2522.ROW=SAE.ECT
    ;Cold Engine Rev Limiter Adjust
    B5203.ROW=GM.RUN_TIME
    B5203.COL=SAE.ECT
    ;MAF Frequency Converions (Low Flow)
    B1097.ROW=GM.MAFFREQ
    ;MAF Frequency Converions (High Flow)
    B1098.ROW=GM.MAFFREQ
    ;AFM Enable Min Vacuum
    B0950.ROW=SAE.RPM
    B0950.COL=GM.GEAR
    ;AFM Disable Min Vacuum
    B0951.ROW=SAE.RPM
    B0951.COL=GM.GEAR
    ;Cam Position ECT Multiplier
    B7930.ROW=SAE.ECT
    B7930.COL=E67.APCYL_DMA
    ;cam Position Low Baro
    B7934.ROW=SAE.RPM
    B7934.COL=E67.APCYL_DMA
    ;cam Position Med Baro
    B7935.ROW=SAE.RPM
    B7935.COL=E67.APCYL_DMA
    ;cam Position High Baro
    B7936.ROW=SAE.RPM
    B7936.COL=E67.APCYL_DMA
    ;Cam Position AFM Mode
    B7937.ROW=SAE.RPM
    B7937.COL=E67.APCYL_DMA
    ;Max RPM For Cam Phasing (Upper)
    B7942.ROW=ECT
    ;Max RPM For Cam Phasing (Lower)
    B7943.ROW=ECT
    ;Max Runtime For Cam Phasing
    B7944.ROW=ECT
    B7950.ROW=SAE.ECT
    B7950.COL=E67.APCYL_DMA
    B7954.ROW=SAE.RPM
    B7954.COL=E67.APCYL_DMA
    B7955.ROW=SAE.RPM
    B7955.COL=E67.APCYL_DMA
    B7956.ROW=SAE.RPM
    B7956.COL=E67.APCYL_DMA
    B7957.ROW=SAE.RPM
    B7957.COL=E67.APCYL_DMA
    B7962.ROW=ECT
    B7963.ROW=ECT
    B7964.ROW=ECT
    ;Fan Power ECT
    G0901.ROW=ECT
    ;Fan Power ACP
    G0902.ROW=SAE.MAP
    Only if the E67 pid exists.
  9. #19
    Aug 2015
    Ok, will have a look through them, they seem to refer to BEN pids mainly.
  10. #20
    Aug 2015
    I have looked through and all pids exist in E67 variants. Also found a few other pids that needed to be changed, I have also linked in the Final Timing pid {B5157}:
    Code:
    ; Date         Who Why
    ; 2015-Aug-19	BS Fix E38 pids to point at E67 pids
    [E67]
    ; Virtual VE tables
    B8101.ROW=SAE.RPM
    B8101.COL=SAE.MAP
    B8101.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8102.ROW=SAE.RPM
    B8102.COL=SAE.MAP
    B8102.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8103.ROW=SAE.RPM
    B8103.COL=SAE.MAP
    B8103.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8104.ROW=SAE.RPM
    B8104.COL=SAE.MAP
    B8104.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8105.ROW=SAE.RPM
    B8105.COL=SAE.MAP
    B8105.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8106.ROW=SAE.RPM
    B8106.COL=SAE.MAP
    B8106.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8151.ROW=SAE.RPM
    B8151.COL=SAE.MAP
    B8151.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8152.ROW=SAE.RPM
    B8152.COL=SAE.MAP
    B8152.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8153.ROW=SAE.RPM
    B8153.COL=SAE.MAP
    B8153.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8154.ROW=SAE.RPM
    B8154.COL=SAE.MAP
    B8154.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8155.ROW=SAE.RPM
    B8155.COL=SAE.MAP
    B8155.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    B8156.ROW=SAE.RPM
    B8156.COL=SAE.MAP
    B8156.RRR=CALC.BEN1_E67,CALC.BEN2_E67,CALC.BEN_AUT1_E67,CALC.BEN_AUT2_E67,CALC.BEN_FJO1_E67,CALC.BEN_FJO2_E67,CALC.BEN_LC11_E67,CALC.BENLC12_E67,CALC.BEN_LM11_E67,CALC.BEN_LM12_E67,CALC.BEN_PLX1_E67,CALC.BEN_PLX2_E67,CALC.BEN_TE1_E67,CALC.BEN_TE2_E67,CALC.BEN_WBC1_E67,CALC.BEN_WBC2_E67
    ;Stoichiometric AFR
    B3671.ROW=GM.E85PCT
    B0138.ROW=SAE.RUNTM
    B0138.COL=SAE.ECT
    B0139.ROW=SAE.ECT
    B0140.ROW=GM.E85PCT
    B0156.ROW=SAE.RPM
    B0158.ROW=SAE.MAP
    B0168.ROW=SAE.TP
    B0168.COL=SAE.RPM
    B3618.ROW=SAE.RPM
    B1501.ROW=SAE.ECT
    B1502.ROW=SAE.ECT
    B1503.ROW=SAE.ECT
    B1504.ROW=SAE.ECT
    B1510.ROW=SAE.BARO
    B0141.ROW=SAE.ECT
    B0141.COL=E67.INVLVTMP_DMA
    B0142.ROW=SAE.ECT
    B0142.COL=E67.INVLVTMP_DMA
    B0143.ROW=SAE.ECT
    B0143.COL=E67.INVLVTMP_DMA
    B0144.ROW=SAE.ECT
    B0144.COL=E67.INVLVTMP_DMA
    B0145.ROW=GM.E85PCT
    B0146.ROW=E67.INVLVTMP_DMA
    B0146.COL=SAE.MAP
    B0148.ROW=SAE.MAP
    B0148.COL=SAE.RPM
    ;Injector Flow Base
    B1215.ROW=E67.INJPDELTA_DMA
    B1210.ROW=E67.INJPDELTA_DMA
    B1210.COL=GM.VOLTS
    B1211.ROW=SAE.MAP
    B1211.COL=GM.VOLTS
    B1213.ROW=GM.IAT2
    B1214.ROW=GM.VOLTS
    B1203.ROW=SAE.RPM
    B1205.ROW=SAE.ECT
    B1206.ROW=SAE.RPM
    B1207.ROW=SAE.ECT
    B1208.ROW=SAE.RPM
    B1602.ROW=SAE.ECT
    B1821.ROW=SAE.ECT
    B1823.ROW=SAE.ECT
    B1824.ROW=SAE.ECT
    B1601.ROW=SAE.BARO
    B1829.ROW=SAE.RPM
    B1829.COL=GM.GEAR
    ;Cranking Idle Air
    B1832.COL=SAE.ECT
    B5101.ROW=SAE.RPM
    B5102.ROW=SAE.RPM
    B5103.ROW=SAE.RPM
    B5146.ROW=SAE.RPM
    B5105.ROW=SAE.ECT
    B5106.ROW=SAE.RPM
    B5106.COL=SAE.ECT
    ;IAT Spark Table
    B5107.ROW=GM.IAT2
    ;IAT Spark Table 2
    B5147.ROW=GM.IAT2
    B5108.ROW=SAE.RPM
    B5108.COL=GM.IAT2
    B5109.ROW=SAE.ECT
    ;EGR Spark Table
    B5110.ROW=SAE.RPM
    B5111.ROW=SAE.RPM
    B5112.ROW=SAE.RPM
    B5113.ROW=SAE.MAP
    B5114.ROW=SAE.RPM
    B5115.ROW=SAE.RPM
    B5116.ROW=SAE.RPM
    B5117.ROW=SAE.ECT
    B5153.ROW=SAE.RPM
    ;Minimum Final Timing
    B5157.ROW=SAE.RPM
    B5157.COL=E67.APCYL_DMA
    B5118.ROW=SAE.RPM
    ;Cranking Spark
    B5119.ROW=SAE.RPM
    B5119.COL=SAE.ECT
    ;Spark Dwell Time
    B5120.ROw=SAE.RPM
    B5120.COL=GM.VOLTS
    B5121.ROW=E67.COILTEMP_DMA
    B5121.COL=GM.VOLTS
    B5123.SAE.RPM
    B5124.SAE.RPM
    B5104.ROW=SAE.RPM
    ;Coast Down Spark
    B5122.ROW=SAE.RPM
    B5125.ROW=SAE.ECT
    B5126.ROW=SAE.ECT
    B5127.ROW=SAE.BARO
    B5128.ROW=SAE.RPM
    B5129.ROW=SAE.RPM
    B5130.ROW=SAE.RPM
    B5131.ROW=SAE.RPM
    B5132.ROW=SAE.ECT
    B5133.ROW=SAE.RPM
    B5134.ROW=SAE.ECT
    B5135.ROW=SAE.ECT
    B1902.ROW=SAE.RPM
    B1903.ROW=SAE.ECT
    B1904.ROW=SAE.MAP
    B1905.ROW=SAE.RPM
    B1905.COL=SAE.MAP
    B1906.ROW=SAE.RPM
    B1006.COL=
    B1918.ROW=GM.IAT2
    B1919.ROW=SAE.RPM
    B1920.ROW=SAE.ECT
    B1927.ROW=SAE.ECT
    B1927.COL=GM.IAT2
    B1928.ROW=GM.KR
    B1940.ROW=SAE.RPM
    B1948.ROW=SAE.RPM
    B1949.ROW=SAE.ECT
    ;Launch Spark
    B1950.ROW=SAE.ECT
    ;Launch Spark Hold
    B1951.ROW=SAE.ECT
    B1954.ROW=SAE.RPM
    B1957.ROW=SAE.TP
    B1957.ROW=SAE.ECT
    B1967.ROW=SAE.RPM
    B1967.COL=
    B1968.ROW=SAE.RPM
    B1968.COL=
    B1969.ROW=SAE.RPM
    B1969.COL=
    B1970.ROW=SAE.RPM
    B1970.COL=
    B1971.ROW=SAE.RPM
    B1971.COL=
    B1972.ROW=SAE.RPM
    B1972.COL=
    B1973.ROW=SAE.RPM
    B1973.COL=
    B1974.ROW=SAE.RPM
    B1974.COL=
    B1975.ROW=SAE.RPM
    B5148.ROW=SAE.TP
    B5149.ROW=SAE.RPM
    B5150.ROW=SAE.RPM
    B5151.ROW=SAE.TP
    B5152.ROW=SAE.RPM
    B2514.ROW=SAE.RPM
    B2514.coL=GM.GEAR
    B2515.ROW=GM.IAT2
    B2515.COL=GM.GEAR
    B2517.ROW=SAE.RPM
    B2517.COL=GM.GEAR
    B2522.ROW=SAE.ECT
    B5203.COL=SAE.ECT
    B0950.ROW=SAE.RPM
    B0950.COL=GM.GEAR
    B0951.ROW=SAE.RPM
    B0951.COL=GM.GEAR
    B7930.ROW=SAE.ECT
    B7934.ROW=SAE.RPM
    B7935.ROW=SAE.RPM
    B7936.ROW=SAE.RPM
    B7937.ROW=SAE.RPM
    B7942.ROW=ECT
    B7943.ROW=ECT
    B7944.ROW=ECT
    B7950.ROW=SAE.ECT
    B7954.ROW=SAE.RPM
    B7955.ROW=SAE.RPM
    B7956.ROW=SAE.RPM
    B7957.ROW=SAE.RPM
    B7962.ROW=ECT
    B7963.ROW=ECT
    B7964.ROW=ECT
    ;Fan Power ECT
    G0901.ROW=ECT
    ;Fan Power ACP
    G0902.ROW=SAE.MAP
  1. Aug 13, 2015: EFILive Public Pre-Release
    Last Post: August 27th, 2015, 10:14 AM
  2. Aug 07, 2015: EFILive Public Pre-Release
    Last Post: August 12th, 2015, 12:46 PM
  3. Known issues with Aug 07, 2015 Public Pre-Release
    Last Post: August 8th, 2015, 11:42 AM
  4. Known issues with July 08, 2015 Public Pre-Release
    Last Post: July 27th, 2015, 05:59 PM
