Results 1 to 5 of 5
Thread: Ls1b pcm won't unlock
    Oct 2015
    Default Ls1b pcm won't unlock
    I've been working on a 2005 Chevy Silverado with a 4.8L and an Ls1b pcm. When I try to read the stock tune from the pcm it recognizes the controller but fails to unlock it and read the tune even when i try the alternate unlock strategies. I was able to read the DTC's and it threw a b1000 ecm malfunction code. I'm wondering if there's something i'm missing or if the pcm isn't any good. Any advice would be appreciated.
    Which V7 and V8 build versions do you have installed...?
    Oct 2015
    For V8 I have version 8.2.2 build 276 and the V7.5.7 build 283
    Jan 2010
    You probably have to change the settings. This was an issue in one of the updates a few months back around april/may.
    These 2 post explain it better.
    https://forum.efilive.com/showthread...l=1#post221779
    https://forum.efilive.com/showthread...l=1#post221834
    This is also related: Error-0333
  1. Ecm won't unlock after tune
    By 05chevy in forum Duramax LB7
    Last Post: April 15th, 2015, 03:17 AM
  2. ls1b car won't start without flashscan V2 plugged in
    By greasess in forum Gen III V8 Specific
    Last Post: April 20th, 2014, 03:08 PM
  3. LY6 E38 PCM to LS1B PCM convertion?
    By trimchip in forum General (Petrol, Gas, Ethanol)
    Last Post: July 14th, 2012, 06:25 PM
  4. How do I unlock the PCM?
    By -=Mod=- in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2007, 12:06 PM
  5. Unlock the PCM
    By ASSAMI in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 15th, 2007, 05:49 AM
