Here is a short log of me manually increasing the AFR, check out what the wide-band is doing with ever step up of the desired AFR.
Im at a loss. Stock injectors, stock injector mapping.
Mitch,
Can you get a log of this (showing GM.AFR, CALC.AFR_LM21, CALC.BEN_LM21)...
( start logging, and while logging is proceeding, goto DVT and force the AFR... then when done, deactivate DVT and stop the log )
Yes, because when the PCM commands some AFR, GM.AFR shows it (and so the BEN should stay the same, as long as the WB followed the AFR).
The wideband follows commanded AFR perfectly if you use the formula V+11. That's not a very wide wideband.
This is the wideband I'm using. Any ideas?
http://www.innovatemotorsports.com/products/lc2.php
This is the setup guide I used.
http://www.innovatemotorsports.com/r...e_tutorial.php
Joe,
I'm pretty sure that's what I did in the log I posted just above. It's a short log showing exactly what i think you are asking about.
Thanks so much guys.
Try switching over to the brown wire and use "Analog out 2". Then do another AFR sweep like you did in your last log.
Just jumping in here, sorry I haven't read the entire thread so what I say may have already been covered.
From the log file it looks like you're using an Innovate side band controller. Innovate uses a programmable stoichiometric value that is used by the wide band to determine AFR and hence (I presume) to determine the output AFR voltage. Are you sure the wide band's stoich setting is correct for the fuel you are using?
You need to use Innovate's Logworks software to set the stoich value.
Paul, I appreciate you taking the time.
I did check the settings, I have the firmware programmer that allows me to setup the controller outputs. I will take a closer look at that. It does kinda seem like statesman might be onto something, it appears like it could be functioning as a narrow band so ill go through all the settings to see. That said when using the Innovative program it is showing me the same values, which should rule out any sort of analog output mapping because I can check it against itself.
Judging by the comments here you guys think its something either with the controller or the inputs itself? Nothing in the tune could cause this type of issue, or nothing easy to overlook? Ill look over all my settings again.
Joe,
Are you saying that this link to setup the controller is incorrect? Im at a loss.
Thanks guys.
Mitch
If you have an LC-2, I would set it back to default, and use the LC-1 calc pids...
if you have a serial comms cable you could use that to connect to V2 (needs null modem gender bender), it gives Lambda and AFR with no conversion to analog needed (i.e. you don't have to worry about which of the the 2 analog outputs you're connected to, and you don't have to worry about voltage offsets).
In its default configuration, the LC-2 (and the LC-1) assign the analog channel like this:
Originally Posted by LC-2 user manual pdf, page 3
