Results 1 to 8 of 8
Thread: V2 LC-1 serial wide band will not read
    Dec 2012
    Default V2 LC-1 serial wide band will not read
    I can not get my LC-1 to work with the serial cable. I have hooked it up analog and used the preset PID list in scan and tune and it works (with a friends V2). The problem is the analog inputs on my V2 do not work. I am using a friends V2 to test with. I am using a NULL MODEM adapter and have checked the pin location and compared to a schematic I found on this forum and they are correct. The serial cable is plugged in to the out plug on the LC-1 and the terminating plug is in the in port. I must be missing some thing or I am lucky enough to own a V2 with dead analog inputs and a LC-1 with bad serial out.
    Try connecting your LC-1 to your friend's FSV2's serial port using the null modem adapter, see if this works first.
    Question: did you configure your FSV2 for the LC-1 (com port is Wideband, Type is Innovate)...?
    Post a pic of the serial cable showing it connected to LC-1 and FSV2.
    Which firmware version is in your FSV2...?
    Dec 2012
ID:	21055Click image for larger version.
ID:	21056Click image for larger version.
    I have tried with both. I just updated the firmware today, 2.07.113
    Dec 2012
    By the way thanks for the quick response.
    No worries.
    Does the Gigaware say "null" or "null modem" on it...?
    Dec 2012
    It says DB9P Serial Coupler part number 26-1410.
    Quote Originally Posted by strokerstang86 View Post
    That's the wrong one (it's straight, it's not null modem i.e. it not twisted/crossed)...
    the correct one is Gigaware part# 26-1411 (it says on it "null modem")
    Dec 2012
    Thanks JOECAR, it was the wrong adapter fired right up with the new adapter.
  1. Newb Setting up serial Wide band
    By HellKnightHicks in forum General
    Last Post: January 16th, 2013, 12:30 PM
  2. I need help with my wide band
    By isak81 in forum External A/D inputs
    Last Post: January 8th, 2012, 03:46 PM
  3. Wide band
    By Harrismarine in forum FlashScan V2
    Last Post: July 6th, 2008, 12:27 PM
  4. The Wide Band....how do we really know...
    By Redline Motorsports in forum General
    Last Post: January 8th, 2007, 06:51 AM
  5. wide band o2
    By woody69 in forum Custom Operating Systems
    Last Post: October 23rd, 2006, 04:19 PM
